04-16-2010, 10:46 AM   #1
Can i step down to a 49mm filter on the FA31mm?
Hey all,
new member here. I'd like to get a polarizing filter, and i was wondering if anybody out there uses the FA31mm ltd with a 49mm filter out front on a cropped sensor body (in my case a k-x). I know i should just go to the store and try it, but thought i'd check to see if anyone else was doing this.
I just figured it's easier (and cheaper) for me to get a 49mm filter which can be used on my other primes and step down on the FA31mm, rather than get a 58, and have to step up my other two lenses. Was hoping to get away with it since I'm just using the center of the image circle anyways, but if it vignettes, then nevermind.
thanks a bunch!!!
04-16-2010, 11:07 AM   #2
RioRico's Avatar
I've stepped down from 58 to 49 with a 28mm lens, and with an old Tak-A 28-80, and I get vignetting on my K20D -- UNLESS I'm doing the step-down for macro work, with a macro adapter or reverse-mounted secondary lens. But just to add a polarizer or other filter, you'll probably lose corners. The general practice when obtaining any expensive filtration is, buy to cover the largest lens you want, then use step-up rings for smaller lenses.
Of course, your mileage may vary. Best to try it out and see.
04-16-2010, 11:32 AM   #3
clm
I tried it with 49mm filters and a hood and never noticed any vignetting, but I didn't try to test or measure for it.
49mm, 49mm filter, fa31mm, filter, k-mount, pentax lens, slr lens, step
For Sale - Sold: Pentax and Albinar 2x TCs, 2 Cokin A filter sets, 49mm Filter and Macro tubes pxpaulx Sold Items 15 02-11-2010 09:09 PM
filter step up rings or filters for every lens? opiet70 Pentax SLR Lens Discussion 6 12-25-2009 02:20 PM
49mm Filter Package - Bargain? Dubesor Pentax Camera and Field Accessories 6 11-06-2008 02:54 PM
For Sale - Sold: FS: 62mm UV filter + step up rings heatherslightbox Sold Items 6 05-07-2008 09:14 AM
For Sale - Sold: B+W 58mm Grad ND 1 Like New! Plus Step-up rings, UV filter and cap GaryML Sold Items 0 04-21-2007 11:16 AM
All times are GMT -7. The time now is 07:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
