04-30-2010, 11:29 PM   #166
Class A's Avatar
QuoteOriginally posted by seacapt Quote
you guys are gonna laugh but I have an old Mamiya Sekor 55/1.4 that is sharp as a razor even wide open.
How does that fit on a Pentax? Or does it not?
05-01-2010, 10:13 AM - 1 Like   #167
seacapt's Avatar
M42 adapter.
05-01-2010, 02:36 PM - 1 Like   #168
Blue's Avatar
No one that's ever used Mamiya glass laughs at it. I have an SX series 28mm that isn't usable on my Pentax bodies without a special m42 adapter to hold the auto aperture pin since they lack the A-M switch but it is one of the best 28mm lenses I have handled personally.
05-01-2010, 08:42 PM   #169
seacapt's Avatar
Blue , y'know what the problem here is? Everytime we (Imean as a group) post something about a cool old lens we drive the price up on ebay .
05-01-2010, 09:01 PM   #170
QuoteOriginally posted by séamuis Quote
Macro-Takumar 1:4/50 preset 1:1
doesn't get much sharper than this I think. it always blows me away, even wide open.
+1 Yes indeed. All of the M42 Macro-Takumar 4/50 versions have superb resolution. However, if by "sharpest" is meant "highest contrast" my vote goes to the M42 S-M-C Macro-Takumar 4/100, also a very high resolution lens.
05-01-2010, 09:42 PM   #171
Class A's Avatar
M42 adapter.
Ah, I didn't know that Mamiya lenses came with a M42 mount. Thanks.
05-03-2010, 07:19 PM   #172
seacapt's Avatar
Like Blue said the later ones require modification to the lens or adaptor because there is no A/M switch , but the glass is super.
05-03-2010, 09:14 PM   #173
QuoteOriginally posted by photogerald Quote
Yes, the FA*200 crop does look sharper but here both shots were taken at the same subject distance. ie- the FA*200 had a 1.45x magnification advantage.
Had I compensated for the focal length difference (by moving closer with the A*135), the A*135 crop would've looked much better.
The fact that the A*135 comes out looking so close to the FA*200 in this test, despite the magnification disadvantage, says a lot about the A*135 I think.
Here I moved closer with the A*135 to give the same approximate magnification as the FA*200 (click to enlarge). There's a bit of camera shake in the A*135 crop, but the resolving advantage should be easy to see.
05-03-2010, 09:48 PM   #174
Pentaxor's Avatar
mind you as you increase crop further, the resolving power of the 135 will lose out evidently. it maybe ok at certain crop magnification such as this example, but further out, it would start to deteriorate. the difference between focal length resolving power is undeniable as well. but for a 135mm, it is one excellent lens. I'm not sure though if it's slower counterparts (2.5, 2.8, 3.5) would show the same resolving power at such cropped magnification.
05-04-2010, 07:36 PM   #175
stover98074's Avatar
Manual Focus Lenses
Old enlarging lenses mounted on a bellows or extension tubes - Fujinon EP 135 (this lens goes to f / 45), Fujinon EP 50, El Nikkor 105.
Prime lens (non bellows or enlarging tube) Vivitar 90 MM 2.5 Macro Lens
05-14-2010, 01:48 AM   #176
hmmm, the first is definitely a bit sharper
05-14-2010, 05:37 AM   #177
I gotta go with my DA 40mm ltd on this one, although I don't own a whole lot of glass so it's not really a stiff competition for me.
k-mount, lens, pentax lens, slr lens
The XR Rikenon 50mm f2 sharpest 35mm lens claim K-9 Pentax SLR Lens Discussion 33 08-13-2012 06:20 AM
Which fast (better than F2) AF lens is sharpest at f1.7. pcarfan Pentax SLR Lens Discussion 4 10-01-2009 02:35 PM
Pentax 67 Sharpest Lens desertscape Pentax Medium Format 6 06-07-2009 05:58 AM
Sharpest lens, any brand, ever? falconeye Pentax SLR Lens Discussion 48 03-24-2009 04:27 PM
landscapes... which lens is sharpest at F16 to F32 etc? slip Pentax SLR Lens Discussion 7 01-06-2007 07:41 PM
All times are GMT -7. The time now is 05:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
