Originally posted by SOldBear The answer is "no."
A step-up ring to a large filter works fine.
Thanks.
Originally posted by SOldBear But since you mentioned 10-20mm lens and CPL: beware that CPL used with ultra wide-angle lens may produce "uneven" lighting. Some people use them together effectively but I myself think it's too much hassle.
Yeah, that is especially true when the sky is involved, which would be the case for lake scenes and the like. But I also use a CPL for waterfalls, in which case it would not be as problematic. I've never used an ultra-wide (my smallest back in the film days was a 28mm), so I'm sure it would take getting used to.
But even if I decide that I don't like the CPL on the 10-20mm, I'd still need the ND at times for waterfalls.
