04-25-2010, 01:45 AM   #1
rustynail925's Avatar
How to clean lens
What is this?
How can i clean a lens with this?
04-25-2010, 02:17 AM   #2
pschlute's Avatar
Looks more like sensor dust to me. Do you only get it with one lens ?
04-25-2010, 02:21 AM   #3
I tried cleaning the sensor w/ a blower and it disappears on that area but appears on another
area. Is it in the sensor?
04-25-2010, 02:33 AM   #4
It's on the protective cover over the sensor. Just make sure to hold the camera with the lens mount facing down to let the dust drop out of the camera body & keep using the blower. If the dust is moving around, it's just a matter of time before it gets blown out.
04-25-2010, 02:51 AM   #5
would the dust removal be able to help?
04-25-2010, 02:56 AM   #6
pschlute's Avatar
QuoteOriginally posted by rustynail925 Quote
The dust removal system shakes the sensor and the dust should fall onto a sticky pad. Howerver some dust can become quite fixed on the sensor cover and you need to blow it away. Use a hand bulb blower. Don't blow on it or use compressed air.
04-25-2010, 03:28 AM   #7
What about the mirror inside is it ok to use a cotton buds to wipe it?
04-25-2010, 06:01 AM   #8
don't touch the mirror. The mirror is for the viewfinder only and has nothing to do with you pictures.
Or better don't touch anything inside the body.
Change fresh batteries.
Go to menu and set the camera to sensor cleaning. This will pull the mirror up so you can clean the sensor.
Don't turn your camera off. Read the manual for instructions.
04-25-2010, 06:15 AM   #9
Oops i just cleaned the mirror earlier using the cotton buds.
I also see something on the viewfinder some mark or something how can i get read of that
04-25-2010, 07:51 AM   #10
you don't have to get rid of that. Just leave it alone unless you can't see anything anymore. The cotton balls will only release more dust into the body. I just played with one over here to make sure, and yes I see little things flying away when punishing them.
04-25-2010, 08:09 AM   #11
I mean when im using it to take pictures
theres something in the viewfinder that cant be removed i dont know whats
causing it but if i take pictures it doesnt appear on the pictures
04-25-2010, 08:54 AM   #12
omega leader's Avatar
Dust in the viewfinder is not a concern, it will not impact the image. It also helps if you do lens changes with the camera pointing down to reduce dust infiltration.
k-mount, lens, pentax lens, slr lens
Clean Pentax SMC Lens trevorgrout Troubleshooting and Beginner Help 8 04-17-2010 05:46 PM
Keeping the lens clean StarDust Pentax SLR Lens Discussion 10 02-22-2009 10:47 AM
How do you clean your lens? gkopeliadis Pentax SLR Lens Discussion 42 06-17-2008 05:07 PM
what do you use to clean your lens? slip Pentax Film SLR Discussion 17 05-25-2007 01:07 PM
How do you clean up an old lens Alvin Pentax SLR Lens Discussion 3 02-19-2007 08:06 PM
All times are GMT -7. The time now is 07:18 PM. | See also: NikonForums.com, part of our network of photo forums!
