04-28-2010, 09:05 PM   #1
Primes to replace DA* 16-50mm
I've found myself really only using the DA*16-50 racked out at either extreme of it's focal lengths.
I've also found that my wide shots don't fill the frame so I suppose I don't need anything quite as wide as 16mm. Ideally I'd like to replace it with one fairly wide prime (Thinking 20mm-30mm) who's IQ would make the 16-50 blush however I'm not adverse to replacing it with two primes if it'll best compliment my other two lenses.
I currently have in addition to the 16-50 the DA* 55 f/1.4 and the DA* 200 f/2.8. I only want to have a four lens kit and I only want the best of the best.
So, this has me thinking the FA 31mm Limited followed by the DA 15mm Limited.
In terms of IQ/sharpness will these two be on par / better than my DA* 55 and 200 and better than my 16-50?
04-28-2010, 09:42 PM   #2
QuoteOriginally posted by noahpurdy Quote
Exactly what I was thinking before I finished reading your post. The 4 lenses would make a very fine kit. Though, the FA35 and DA35 are no slouch lenses but not quite as special as the 31mm Ltd.
04-29-2010, 05:34 AM   #3
You say you want something not quite as wide as 16mm, then you suggest the 15mm? What about the 21mm instead?
At the wide end, the 16-50mm has quite a lot of barrel distortion, and the flare resistance is poor as well, so the primes will definitely perform better in that regard. In terms of sharpness, I don't believe the difference is very large.
The 31mm and 55mm are obviously excellent choices for the rest of the range.
04-29-2010, 06:40 AM   #4
axl
If you don't need/want anything as wide as 16 then I can't see you liking DA15.
I'd suggest either DA21 or FA20/2.8. Both very well regarded and neither is really big.
For the mid range you can't beat 31ltd and you already have DA*55.
21-31-55 would one terrific line up IMO
04-29-2010, 06:40 AM   #5
I'd almost say consider the DA 21 & DA 40 as a compliment to your 55 & 200. Those 2 lenses are compact enough you could carry them around pretty much all the time anyway...
da*, k-mount, pentax lens, primes, slr lens
For Sale - Sold: 3 Manual Primes: A-28mm f/2.8, A-50mm f/1.7, and M-50mm f/1.4 (US) Rich_A Sold Items 6 03-24-2010 02:25 PM
Replace 16-50 with primes? Crepusculum Pentax SLR Lens Discussion 21 10-12-2009 12:47 AM
regarding Pentax 50MM Primes Pentaxor Troubleshooting and Beginner Help 5 05-27-2009 10:41 PM
50mm Primes choiboi Pentax SLR Lens Discussion 10 07-15-2008 10:19 PM
Pentax primes 40mm 2.8 or 50mm 1.4 fevbusch Pentax DSLR Discussion 19 02-04-2007 09:55 AM
All times are GMT -7. The time now is 11:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
