04-29-2010, 09:43 PM   #1
Pentax DA 12-24mm purple fringing monster? correctable?
there is some talk going on about the Pentax 12-24mm and i although thought about buying this lens. i read all the reviews and i know it's weakness is purple fringing.
in these reviews they always point out that it's easily correctable in post processing. so i looked at many pictures taken with this lens and almost every picture with some harsh contrast shows massive blue, green and blue fringing.
i attached some findings.
i tried to correct them in Lightroom3 beta but failed to completely remove them or keep the quality good enough. anybody can tell me if it's possible and if yes how?
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
04-29-2010, 09:45 PM   #2
another bunch if samples
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
04-29-2010, 10:19 PM - 1 Like   #3
Quality is going to be subjective for this but here's one way I go about it. I've found, and this is true with All of my lenses, it's a matter of not over exposing the shot and getting the WB looking right. You can see in the window, how this shot started out (the picture is of the dog at the back fence). These are screen shots from ACR. These steps can also be taken in Lightroom.
The First thing I do is adjust the White balance to kill most of the fringing.. So we go from this..
To This.
After that I go up close and personal to adjust the CA sliders and kill or balance out as much of the remaining stuff as possible.
I do my sharpening, contrast adjustments, etc then open the image for the final JPG edit. In this case, it's bringing down the exposure of the sky to give it some detail. Then applying masks where I do (or don't) want the effect to happen.
Remember, I said the picture is of the dog.
This doesn't work with everything but it worked great here. I've said it before, I'll say it again, and again. I can make ANY lens Fringe. It helps though to get it right the first time.
This Is a crop but there was no CA/PF correction done.
04-29-2010, 11:01 PM   #4
Pentaxor's Avatar
very helpful tutorial Jeff.
since you already mentioned some PP work, I would like to point out some basics or things that would make PP less work.
here is what I do first. I decrease the contrast depending on the light intensity of the shot. try to shoot at around 14mm or more whenever possible. CA/PF is very strong at 12mm. avoid shooting at f4 if light intensity is strong. I would recommend f8 or over. if you have done these steps, post-processing later on would be much easier.
oh and there is the simplest and easiest solution of avoiding and eliminating PF/CA completely. shoot B&W.
04-30-2010, 03:57 AM   #5
JHD
QuoteOriginally posted by Pentaxor Quote
or just get a Sigma 10-20
04-30-2010, 06:22 AM   #6
Wheatfield's Avatar
QuoteOriginally posted by JHD Quote
I expect it can be made to PF if someone tries hard enough.
04-30-2010, 09:09 AM   #7
i've checked the exif data of this samples and it's true most of them where shot below f8 (but most of them one stop below) and between 12-16mm. in terms of usability this means i should avoid using it's wider end on bright days or stopping it down if possible.
thanks jeff for the tut how you manage the CA with this lens. what about the lens profiles in adobe's new camera raw?
i saw i short movie how these lens profiles could correct most of the lens CA and distortion. i wonder how this works out for this lens because this would be a one click action.
this is the only area where the sigma beats the pentax and i still prefer the pentax because of it's longer end.
04-30-2010, 10:20 AM   #8
Pentaxor's Avatar
QuoteOriginally posted by testlord Quote
just be aware that it doesn't eliminate CA completely but minimize the intensity of CA to a low level.
also mind you that any lens will display a certain level of CA under extreme conditions.
12-24mm, k-mount, lens, pentax, pentax da 12-24mm, pentax lens, reviews, slr lens
DA 10-17 purple fringing rpriedhorsky Pentax SLR Lens Discussion 13 02-07-2009 04:46 AM
Purple fringing on DA* 16-50 spinmar Pentax SLR Lens Discussion 14 02-03-2009 07:03 AM
Purple Fringing paolojackson Digital Processing, Software, and Printing 2 10-06-2008 05:25 PM
Oh no! Purple fringing! NaClH2O Post Your Photos! 6 03-27-2008 05:28 AM
Purple Fringing Stratman Pentax SLR Lens Discussion 7 04-29-2007 01:07 PM
All times are GMT -7. The time now is 05:33 PM. | See also: NikonForums.com, part of our network of photo forums!
