Originally posted by tunarudi
Hi everybody!
Trying to get a fast glass and wondering about these two lenses.
I will go for the Pentax 300mm f2.8 but I can't afford to put an order and pay the huge price. Any advice?
Hi Xavier,
The Tamron is a very competent lens. The only optical fault is that it exhibits some CA/PF in high contrast areas at wider apertures. It's sharp enough to stand up to TC use, and the usually supplied SP 140F 1.4x TC for the Adaptall2 series works very well with it. I've also gotten very good results with the Pentax F 1.7x Auto Focusing Adapter with it -- and with these two TCs stacked. After trying the AFA, I pretty much never took it off the lens, so I had an Auto Focusing 510mm f4.8 and an AF 714mm f6.7, both at the size and weight of a relatively light 300/2.8 and under $1000 USD for my copies.
The AFA is probably the only area where Pentax actually enjoys an advantage for long glass fans over the competition.
Here's an admittedly lucky shot taken with a DS, the Tamron and stacked TCs. This was handheld with the lens at @ f4
and a 100% crop near the center of the frame, no PP, or resizing
IMO, this is easily the best bang for the buck. You do have to get a PK/A adapter for the lens, and they've gotten to be a bit hard to find and relatively expensive, but the lens can be gotten with any mount, and converted to Pentax with the adapter. They are pretty commonly found in Nikon and Canon mounts, an you can get a "user" grade lens with clean glass for as little as $400 USD.
The older Sigma EX 300/2.8 APO (pre-DG model) could be another choice if your budget can bear $1500-2200. It not too far off the FA*300/2.8's performance at about $1000 less. The most significant differences are AF, it's maybe a touch sharper, and it controls CA/PF better wide open. You have to pay a substantial amount more to gain a little IQ in this class of lens.
Here's an example from the Sigma with the K20 + 1.7x AFA (510mm) The lens was wide open at @ 15 feet, slightly cropped and sharpened only enough to overcome the softening from resizing.
I rarely shoot either without at least the AFA. For me, it's perfect for my purposes, offering a built-in focus limiter, increased AF speed on any body, and very competent 1.7x magnification. I even use one with my FA*300/4.5. It's a bit slow at f7.7, but the AF works in just about any but the darkest daylight conditions, and it gives me at least Bigma performance in a lens that's about 2 lbs and a lot smaller.
I also have an FA* 300/2.8, but you've already mentioned it's a bit outside your price range. It's a better lens -- not a ton better, but it's easily best in class in the K mount, but will add at least another $1000 to the entry price.
Scott
