Originally posted by blende8 I had an Auto Bellows K and I can only say that I couldn't mount it on my K10/K20 without an extension tube because the flash nose was in the way.
There is a coupler; one side is a K-mount (similar to that of a pK-mount lens), the other side of the coupler is attached to the bellow, kept in place by a simple knurled screw.
If you leave the coupler attached to the bellows, then trying to attach the whole thing to the camera, you can't rotate the bellows to lock it to the camera body.
The "correct" way is: (1) Remove the coupler from the bellows and attached it to the camera body, then (2) Attached the bellows to the coupler, tighten the knurled screw.
Originally posted by blende8 The "Auto" option isn't much worth anyway for a digital body because you cannot fit the mechanical release cable to the body.
Use the double-ended cable release to close down the lens, then use a different remote to trigger the shutter.
