yttrbium:
Thanks a lot for "mushy button syndrome" cure link! I took mine apart a couple times and never could figure out a fix. I never thought you could pry the back off by itself...d'oh!! Still I want to order one of the version II's.
I also need to figure out a fix for whatever I did on one of my exploratory surgeries because the head is floppy in its rotation though I might have actually broke that part...sigh...still I like these flashes for the cost as my needs are just small studio/table top stuff.
EDIT: Nice....took about 10-mins total for the fix. And I was able to remember what was wrong with the head rotation. I think I lost a screw wehn I took the case apart or just forgot to put it in place. Anyway, the result was the body would not close completely so a couple wraps of duct tape and viola, fixed that prob too. Love these inexpensive flashes that you can self-service after you self-induce error codes when making them, ahem, better...
---------- Post added 06-06-2010 at 09:50 PM ----------
Originally posted by eByong Hi i'm about to purchase this Flash - YN460-II Speedlite
i need some feedback if this Flash is compatible with my K-X?
Just a note that unless HoyaTax changed the mount (no they din't) there should not be any issue with the K-x. The only thing I noticed with my K20D was at first the plastic foot on the flash itself was a bit snug and did not want to slide into place. So be gentle the first few times you mount it, after that the foot will have had some wear to it and slip into place just fine. Or ya might not have any issues at all.
