Hello,
Sorry, I just saw your question this morning.
To use your flash off camera, you will need an off shoe cable.
With the Pearstone Duo TTL Off-Camera Flash Cord you can set up a single flash for off-camera lighting and retain your entire camera's TTL (through the lens) flash functions. Multiple contact pins support TTL-compatible flashes used with Canon, Nikon, Fujifilm, Pentax and Samsung digital cameras. The off-camera hot shoe can mount to accessory shoes or 1/4" 20 threaded studs on tripods, booms, or light stands.
Pearstone Universal Duo TTL Off-Camera Flash Cord (3') OCD-U3
The Pentax Off Camera Shoe Adapter F provides off-camera TTL flash capability for Pentax cameras when used in combination with:
Dedicated Cords & Modules
The Manfrotto 330B Macro Flash Bracket weighs only 0.8 lb, has a load capacity of 2.3 lb, and allows for a camera and two shoe-mount flash units to be used simultaneously on a tripod head. Goes on either 3/8" or 1/4" tripod screws and can accommodate the camera in the vertical or horizontal position.
Manfrotto 330B Macro Flash Bracket 330B B&H Photo Video
This is a flexible gobo clamp arm that mounts into the camera's flash shoe. Can be used to hold a reflector, sun shade, backgrounds, or filters in any position. Ten inches long, with removable snap segments, and spring clip. Includes two high-key white and two low-key black vignettes, three black flags, two Flexiglass mirrors, and an 18% grey card.
Delta 1 Flash Shoe Arm Kit 46184 B&H Photo Video
The CAM Engineering Reporter Flash Ring is a tool that is ideal for reporters and event photographers. It allows any flash to rotate around the camera's optical axes, and keeps the flash centered above the lens in either horizontal or vertical camera positions. The bracket will not restrict your hand's access to the vertical grip or vertical shutter release button when the camera is in the "portrait" position.
CAM Engineering Reporter Flash Ring RFR100 B&H Photo Video
C h u c k C a p r i o l a
Live Chat and E-Mail Sales Manager B&H Photo-Video
Thank you, we appreciate your business.
*** Peace on Earth ***
