10-30-2013, 01:45 AM   #1
Ring flash LED or Twin Tube
would appreciate some help here thanks, I was looking at purchasing a ring flash either the twin tube or the LED one nothing to expensive, around $100 or less ??, I was aiming at the twin tube if that 's the better choice?, confused?, I have the pentax k200d
10-30-2013, 12:39 PM   #2
B&H Photo Specialist
Chuck-B&H's Avatar
Hello,
Basically, the difference would be the light source. Strobe tends to output more light, continuous light sources make it easier to see what you are getting, focus and meter your subject.
The STL-80R LED Macro Ringlight Flash and Continuous Light from Stellar Lighting Systems is a versatile LED ringlight that can be used as a flash as well as a continuous-light LED. It's been specially designed for macro photography. Equipped with 80 bright white LEDs, it features a light output of 600 lumens as a continuous light (f/4.0 at 2' and 100 ISO). A set of adapter rings makes it possible to use this light with 55mm, 58mm, 62mm, 67mm, 72mm and 77mm lenses. It runs on 4x AAA batteries.
C h u c k C a p r i o l a
Live Chat and E-Mail Sales Manager B&H Photo-Video
Thank you, we appreciate your business.
*** Peace on Earth ***
10-30-2013, 08:29 PM   #3
thankyou for your reply, will look at ordering one from you shortly, could you also suggest a suitable flash for the hot shoe that can be turned in any direction ( turned up 90% and also swivals) at a reasonable price thanks
10-31-2013, 06:36 AM   #4
Chuck-B&H's Avatar
Hello,
The Pentax AF-540 FGZ is a professional flash unit that is fully compatible with the entire line of Pentax cameras, from the original 67 to 645N II & MZ-S, MZ-SD or digital *ist, K100D, K110D and K10D series cameras. It will support advanced flash functions of even the latest digital SLR camera models.
The VS-510P Wireless TTL Shoe Mount Flash from Bolt is a dedicated flash for use with Pentax & Samsung DSLR, mirrorless or point-and-shoot cameras. The VS-510 features a guide number of 141' at ISO 100 and an adjustable tilt head with five positions: 0 to 90. You can also twist it to the left up to 120 and to the right up to 180. It covers a 24-105mm range (in 35mm full frame format) and also offers rear curtain synchronization for shooting at slower shutter speeds. The included stand allows you to set the flash up on a flat surface, or to attach it to a tripod head, light stand, or clamp that has a standard 1/4"-20 mount.
Chuck
11-09-2013, 02:46 PM - 1 Like   #5
Thanku Chuck, you and your team have been a big help, thanks again
flash, tube
Yongnuo WJ-60 LED macro ring light. cyclone3d Flashes, Lighting, and Studio 13 02-02-2015 04:19 PM
Polaroid LED Ring Flash photolady95 Flashes, Lighting, and Studio 22 02-14-2014 09:45 AM
LED ring flash kempie Flashes, Lighting, and Studio 10 08-28-2012 04:06 PM
LED Ring Flash: Did I really need to know this? Lex Madera Flashes, Lighting, and Studio 3 08-16-2011 01:06 PM
Opinions: Ring light or Ring Flash Peter Zack Flashes, Lighting, and Studio 8 07-14-2007 07:44 PM
All times are GMT -7. The time now is 04:04 PM. | See also: NikonForums.com, part of our network of photo forums!
