06-14-2016, 01:40 PM   #1
glee46's Avatar
Items needed for b&w Developing
I'm trying to put together a kit for developing B&W film. I know most of the items I need, but some I don't. I would like to talk to a sales rep, ask them what I want to do, and order all of the supplies & gear from one place.
Thanks
06-15-2016, 11:52 AM   #2
B&H Photo Specialist
Chuck-B&H's Avatar
Hello;
I ran my own darkroom for 20+ years, printed for photographers and set up and ran a few school traditional programs here in NYC. I would be happy to assist you. Do you want to tell me what you already have and I'll fill in the blanks or would you prefer I start from the beginning?
Chuck
06-15-2016, 08:19 PM   #3
glee46's Avatar
Here's What I Think I Need
Thanks Chuck,
At this point in time, I only plan on shooting & developing B&W. Here is the list of what I think I need. A few of the items I have already. Everything I've listed is from B&H (On my Wish list)
I know I need a canister which will fit 2 reels.
  • Samigon Stainless Steel Tank with Plastic Lid for 2x35mm or 1x120 Reel B&H # SATSSLP120 MFR # ESA345 (Is this a good one?)
  • Dot Line DLC Film Cassette Opener B&H # DOCO MFR # DL-6060
  • 213I10 Karter Scientific 10ml Glass Graduated Cylinder, Single Metric Scale (I have one)
  • Glass Stirring Rod - 10" Long, 6 MM Diameter - 3 Pack (I have these as well)
  • Corning Pyrex Griffin Beaker Set 0f 5. ( I have these)
  • I'm going to bypass the squeegee & use clean micro-fiber cloth.
  • Temperature Gauge (I have a Weber Digital Gauge)
Chemicals:
  • DEVELOPER - Ilford Ilfosol-3 Film Developer for Black and White Film (500ml) B&H # ILI3500ML MFR # 1176108 ( I know this is not reusable. How many do you recommend? Does it also come in power form? I'll be developing 2 to 3 rolls a month.
  • STOP BATH - Ilford Ilfostop Stop Bath (500ml) B&H # ILISB500ML MFR # 1893870
  • FIXER - Ilford Rapid Fixer (Liquid,1 Liter) B&H # ILRFL MFR # 1984262
  • WETTING AGENT - Edwal LFN Wetting Agent for Black & White Film & Paper (3/4 oz) B&H # EDWALFN.75O MFR # EDLFN34 ( Do I need this? I see where some use dish soap)
  • Delta 1 Datatainer Chemical Storage Bottle 128-oz (One Gallon) B&H # DEDG MFR # 11140 - Do I need 2 or 3? Gallon Jugs to Recycle the chemicals I can use again.
  • And of course, more film: Ilford Delta 100 Professional Black and White Negative Film (35mm Roll Film, 36 Exposures) B&H # ILD10036 MFR # 1780624
Below is the film that I have & will be developing. I'm sure I'll be trying out a few other B&W types that the PF group might suggest.
Ilford XP-2 Super Sharp B/W Professional Film 400
Ilford HP-5 Plus 400 B/W Professional Film
Kodak 8292443 T-Max 100, Black/White Film 35mm
Kodak 8667073 Tri-X Pan 400 B/W Film, 35mm
I have a dark room with absolutely no light, so I won't be a changing bag.
If you think of anything else, ie, better film, canister, & so on. If so, please let me know & I'll be putting in my order from B&H.
Thanks again for the help.
06-16-2016, 10:12 AM   #4
Chuck-B&H's Avatar
Hello,
Excuse the cut and paste.
Yes
Yes
Ok
I would not [and never did] touch wet film.
Accurate temperature is the key.
Chemicals:
Ilford Ilfosol is liquid only. Be careful storing chemistry, once open it ages poorly. D76 has been around for ages for a reason. I always experimented and always came back to it B&H # KOD76L
Ok, I used water. Make sure it's the same temp as your chemistry.
Ok
I never used a pre wetting agent but the Edwal is good.
I personally mixed what I needed and then dumped. I never saw the economic return on bulk mixing and storing of chemicals nor bulk film loading for that matter.
Great film.
This is C-41 process [color print film]. Mostly what I use now.
My most used B+W traditional film, I find it scans great as a well as B&H # AGAP6A4360
My experience is Tmax film is very unforgiving to casual exposing and processing. If you're very exact in your methods, Tmax is a great. Me, I learned to burn and dodge really well .
A CLASSIC
What is "absolutely no light" to your eye, is not the same with film. I would reconsider a changing bag and not risk finding out you have light leak.
1) Running water.
2) Clean place to hang and dry your film, a 36exp roll is approx 6ft in length.
3) Clothes pins to hang wet film.
4) B&H # BEBAR & B&H # PR357525 I was a 5exp cut guy, never liked 6 across.
5) B&H # KOPF200PQ Thsi will allow the film to dry evenly.
This should get you started, please let me know if you need anything else.
Good luck !
Chuck
06-16-2016, 02:35 PM - 1 Like   #5
glee46's Avatar
QuoteOriginally posted by Chuck-B&H Quote
Hello,
Good luck !
Chuck
Thanks Chuck for all the help, I really do appreciate it.
06-16-2016, 04:36 PM   #6
glee46's Avatar
The Samigon Stainless Steel Tank with Plastic Lid for 2x35mm Doesn't come with reels. Can I use plastic reels with this or do I have to go with SS?
06-17-2016, 10:44 AM   #7
Chuck-B&H's Avatar
Hello;
Generally speaking, plastic reels are made for specific tanks or tank systems [back in the day]. Use SS, they are better and once you get the hang of loading much faster.
Chuck
06-21-2016, 06:00 AM - 1 Like   #8
glee46's Avatar
Chuck,
Once again, thank you for your time & knowledge.
Hello;
Chuck
Doing C-41 at home If you understand B&W developing Jamey777 Film Processing, Scanning, and Darkroom 16 08-06-2014 08:42 AM
B&W developing and printing in Melbourne - where should I go? DanielT74 Film Processing, Scanning, and Darkroom 10 02-11-2011 04:43 PM
Jumping into the b&w film developing world barbosas Film Processing, Scanning, and Darkroom 11 12-27-2010 01:30 AM
Starting B&W film developing. PollitowuzHere Pentax Film SLR Discussion 14 03-24-2010 01:40 AM
Developing my first roll of B&W. jbrowning Pentax Film SLR Discussion 13 01-31-2009 02:00 PM
All times are GMT -7. The time now is 10:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
