06-22-2016, 09:21 AM   #1
just_life_photograph's Avatar
advice needed on flash purchase
I have GOT to purchase a bounce flash and I don't know where to begin. I am simply an amateur so I don't need anything to expensive. I will be taking some 'headshots' for my chiropractor's website and I know my on-camera flash just won't be flattering.
Thanks!
06-27-2016, 02:36 PM   #2
B&H Photo Specialist
Chuck-B&H's Avatar
Hello;
Unless you tell me otherwise, I will assume you are using a Pentax camera and will want to take advantage of TTL [Through The Lens] automation.
I feel the best bang for you dollar is VS-570P Wireless TTL Flash from Bolt.
It's fully compatible with Pentax/Samsung's TTL, including use as a wireless master or slave TTL flash, the VS-570P allows photographers to work quickly and comfortably by knowing that settings can be easily determined with the camera's automatic metering system. This unit also has good power output with a guide number of 141' at ISO 100 and 50mm and can cover a range of focal lengths from 24-105mm using the zoom head, or as wide as 18mm with the pull-out diffusion panel. You can even control output manually with power settings from 1/1 to 1/64.
The 9 x 9" Impact Micro Quikbox is a great way to expand the capabilities of your on-camera, shoe-mount flash. The Quikbox lives up to its name by opening and assembling in seconds. Just pop open the softbox, add the diffusers, fasten your flash to it with the softbox's touch-fasteners, slip the flash into the camera's hot shoe and you're ready to shoot.
Chuck
06-28-2016, 05:42 AM - 1 Like   #3
thanks so much!
flash, purchase
Advice on Pentax K1 Needed HAC Welcomes and Introductions 17 08-01-2017 07:47 AM
Purchase Advice Needed NiftyFifty Pentax DSLR Discussion 15 12-21-2013 05:37 AM
Advice needed on recent purchase of damaged lens davidreilly3207 Pentax SLR Lens Discussion 12 12-03-2013 07:44 PM
K5, rear curtain sync flash in manual mode, advice on what flash to buy needed! 5R7 Flashes, Lighting, and Studio 4 03-25-2013 08:12 AM
Flash advice needed pentaxbling Pentax DSLR Discussion 6 10-31-2007 10:30 AM
All times are GMT -7. The time now is 01:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
