07-11-2016, 02:01 AM   #1
BigMackCam's Avatar
Non-Pentax off camera flash question
Hi
My full-frame camera is a Hasselblad HV (Sony A99 equivalent) bought from B&H, and I use a Metz 52 AF-1 speedlight with Sony multi-interface which I'm very happy with. I use the same model speedlight with my Pentax cameras, and on those I use an off-camera flash cable so I can hand-hold the Metz. This is my preferred method of use. I'd like to do the same with my HV, and I recently bought the "Vello Off-Camera TTL Flash Cord for Sony Cameras with Multi Interface Shoe (3')" which works well, but is too short. Is there a longer version of the cable, or - alternatively - can you recommend a wireless trigger solution that would work with the stated equipment?
Thanks in advance for your help.
07-13-2016, 09:32 AM   #2
B&H Photo Specialist
Chuck-B&H's Avatar
Hello;
Sorry, no longer cable.
The Nissin Air 1 Commander: featuring the Nissin Air System with 2.4 GHz radio transmission for wireless master TTL control over NAS-compatible flash units. This unit is compatible with Sony cameras with Multi Interface Shoe that utilize ADI / P-TTL metering and offers a triggering range of up to 98'.
Using an Air 1 Commander for the Sony ADI / P-TTL system and the Air R Receiver, photographers can now set up and control numerous flashes in an off-camera setup at distances up to 98'. The receivers add wireless slave TTL functionality with support for high-speed sync up to 1/8000 second, manual power control, and manual zoom, with the ability to select between 8 channels and organize 3 groups.
Chuck
07-13-2016, 04:43 PM - 1 Like   #3
BigMackCam's Avatar
QuoteOriginally posted by Chuck-B&H Quote
Hello;
Chuck
Thanks, Chuck - much appreciated
cable, camera, camera flash, flash, hv, metz, non-pentax off camera, off-camera, sony, speedlight
K5ii off camera flash non-exposure chiefsilverback Flashes, Lighting, and Studio 24 02-17-2016 10:37 AM
Off Camera Flash Question NiftyFifty Flashes, Lighting, and Studio 12 01-22-2013 06:34 AM
Cheap vs expensive non-TTL off-camera flash PentaxLearner Flashes, Lighting, and Studio 18 03-31-2012 05:22 AM
Tips for using non-ttl flash off camera F8&Bthere Photographic Technique 15 08-16-2009 06:04 AM
HSS with a non P-TTL Flash off camera? Not Registered Flashes, Lighting, and Studio 13 12-05-2007 12:12 PM
All times are GMT -7. The time now is 08:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
