07-06-2017, 06:46 PM   #1
I keep getting the same Pentax Grip from you guys with issues.
The first grip I received from B&H, the K1 connector gasket fit snuggly into the slot within the grip. However there was another issue with either the camera or the grip causing me to have to pull the battery multiple times in order to reset the unusable K1. Well I finally got a body that works but I am on my 4 th grip that has a weird issue. The black sealing gasket on the base of my K-1 doesn't seat firmly in the allotted slot of the grip. Either B&H keeps sending me the Grip i return to them or this is a defect. I even had Ricoh send me another gasket to see if that was the issue and both of them fail to fit securely. I have always had a grip with my camera but I am scared if i use the grip in the field, that i will misplace the sealing gasket. I am talking about the black one not the white clear one that comes with the grip.
Does everyone that own a K1 and a BG6 Grip have the same issue or do I need a 5th grip. If so how can I insure B&H isn't just sending me back the one I sent them?
Help please!
07-13-2017, 11:08 AM   #2
B&H Photo Representative
henryp's Avatar
We appreciate your frustration. When a customer returns a product to us he or she states is defective it is returned to our supplier. If you want to be doubly sure, order and pay for another grip and then return the one you have for a refund, not a replacement.
camera, gasket, grip, issue, k1, pentax grip, slot
What kind of time are you guys getting before the thermo-sensor goes off? John Araki Video and Pentax HDSLRs 25 04-20-2011 07:01 PM
SDM firmware vote for the status quo. Let's keep it all the same! Russell-Evans Pentax DSLR Discussion 16 11-29-2009 12:06 PM
85mm vs. 50mm which is which (same subject, same aperture, same magnification) stevebrot Photographic Technique 50 07-01-2008 09:49 AM
All times are GMT -7. The time now is 02:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
