02-25-2021, 06:47 AM - 3 Likes   #1
B&H Photo Specialist
Chuck-B&H's Avatar
Today's Deal Zone Special on Metz compatible flashes for Pentax
Hello everyone, I thought you would be interested in knowing about todays Deal Zone Specials. Specials last for either 24 hours or when supplies run out.
Enhanced with an adjustable LED video light and high-speed sync, this Mecablitz 44 AF-2 Digital Flash from Metz is a great addition to any Pentax camera kit. This model is compatible with the system's P-TTL metering for accurate, automatic control over light output, though it still offers full manual control for those who desire it. With a guide number of 144' at ISO 100 and 105mm and a zoom head with a range of 24-105mm, this flash is able to balance size with versatility. For wider optics, a pull-out diffuser panel can expand the coverage to 12mm. The head also boasts the ability to tilt upwards 90° and rotate right 120° and left 180°. Additionally, this model can be used as a remote TTL slave with compatible system flashes.
The Mecablitz 52 AF-1 digital Flash from Metz is a shoe mount flash, with an illuminated rear touchscreen, designed to be compatible with Pentax/Samsung cameras featuring P-TTL. This flash also has a high guide number of 170' at ISO 100 and 105mm as well as a built-in USB port that allows for future firmware updates via the internet. A high quality metal base allows quick and easy attachment to the camera. The 52 AF-1 is designed to fully support a Pentax/Samsung camera's P-TTL system. It can be operated as a TTL slave unit that can be controlled by the camera's own built-in commander mode or as a master itself.
Improve your on-camera lighting with the Mecablitz 26 AF-2 digital Flash from Metz. This model is designed to work with Pentax cameras which feature P-TTL. It has a guide number of 85' at ISO 100 and with the telephoto attachment. Integrated into the flash is a wide-angle diffuser which increases coverage from 24-85mm with the use of different attachments. The 26 AF-2 also has an LED video light with 2 output settings as well as the ability to tilt upward 90° for bouncing your light.
Chuck
af-2, flash, guide, iso, light, mecablitz, metz, model, p-ttl, pentax
Great Special Pentax-Deal - only two days, today last day acoufap Pentax Price Watch 3 09-01-2018 10:09 AM
Are the dedicated Metz flashes fully compatible with current Pentax DSLRs? Eric Seavey Flashes, Lighting, and Studio 6 02-08-2011 06:23 PM
New Metz Flashes Pentax Compatible Christopher M.W.T Pentax News and Rumors 2 08-21-2010 06:15 AM
All times are GMT -7. The time now is 04:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
