06-15-2010, 09:48 AM   #1
cheekygeek's Avatar
How to Build a Darkroom Sink
Commercial darkroom sinks are expensive, but a nice big flat sink is a great aid to turning that downstairs room or bathroom into a working darkroom. However there is really nothing to building your own:
FILM PHOTOGRAPHY: How To Build A Darkroom Sink
TIP: Size your sink so you can handle the biggest paper development trays you plan to process. (Not as important if you are using a Jobo CPP-2 or other roll processor.)
Also, paint it black. You don't need any stray photon bouncing around in there.
Another idea: make the sink hinge onto a wall and have PVC drain into the tub or shower (not physically connected). This might be an option if you are making a smaller sink and don't want to permanently give up the floor space.
06-15-2010, 11:58 AM   #2
Ratmagiclady's Avatar
QuoteOriginally posted by cheekygeek Quote
There are a lot of ways to go about it, depends what you're working with.
But.
I wouldn't paint your sink black, not where the liquid goes, it'd be annoying and wouldn't last, rather the paint would start coming up, and probably gettting in everything.
Make it to be clean and stay clean.
And not get messed up.
Just build a splash if it's too close to the enlarger. Occasional drops of water or chemistry are probably a bigger problem than photons, if so.
06-15-2010, 02:32 PM   #3
cheekygeek's Avatar
QuoteOriginally posted by Ratmagiclady Quote
Marine Epoxy Paint
06-15-2010, 03:27 PM   #4
I still wouldn't. To be quite honest, your sink should not be your outstanding light leak/reflection concern. Espoecially down inside it. You want it scrubbable, anyway.
06-16-2010, 07:35 AM   #5
graphicgr8s
Guest
Have to agree with the Rat Lady on the black paint. All of the commercial sinks I've used are stainless. And reflective. In the "article" he says to use polyurethane on the front. Not. Use the same paint you use for the interior. Regular poly will degrade way too fast. You could also use Klenk's Tub and Tile Epoxy. I use to use it when I was rebuilding/refurbishing commercial film processors. And I guarantee those saw more use than the home sink and held up well.
I just wonder if with all the wood movement however it would actually stay water tight. One thing the article doesn't get into is if the plywood is bowed/warped (and it will be) putting the high points together and using that to advantage for gluing and clamping.
06-16-2010, 07:53 AM   #6
I've seen a lot of these articles over the years, and the one suggestion I can recall is to use the paint that they use on boats. Waterproof and durable, it should stand up to years in a darkroom.
06-16-2010, 10:42 AM   #7
graphicgr8s
Guest
QuoteOriginally posted by Wes Medlin Quote
Depends on the paint. Most boats today have the color in the gelcoat. And bottom paint is designed to slough. And some release chemicals to deter barnacle formation. Epoxy is about the best. Or fiberglass resin. Which is basically an epoxy.
06-17-2010, 06:09 AM   #8
I made my sink out of plastic sheet (4-5mm). Glued together and sealed with a bead of silicon sealant. It's 8 years old and looks almost like new (some sealant has stained slightly). Splashback is the same stuff which comes in handy to squeegee Fibre prints. Only thing I'd change is I'd make the sides/front much lower as I've never spilt anything more than a few drips when trying to pour a tray of chems back into a bottle without using a funnel
06-17-2010, 06:33 AM   #9
graphicgr8s
Guest
QuoteOriginally posted by HGMonaro Quote
By plastic sheet do you mean acrylic? If so and you use the glue designed for it it's like pvc. A solvent welded tray that's watertight. I made my fish tank filters out of it and it still going.
06-17-2010, 09:51 PM   #10
I can't remember what glue it was (probably nothing special as I didn't know about acrylic glue creating a watertight seal), I added the sealant, even if it was only to make the joins look 'nice'. I originally wanted to get it plastic welded but couldn't find anyone local that could do it at the time. Afterwards I had a friend tell me they knew of someone, but so far it's held up quite well. If it does come apart, I'll be investigating correct glues! thanks!
darkroom, film, photography, sink
Darkroom.. tonyjayice Film Processing, Scanning, and Darkroom 17 06-21-2010 09:47 AM
Misc Kitchen sink Petermgr Post Your Photos! 13 02-03-2010 08:17 PM
Something to sink your teeth into. flyer Pentax News and Rumors 29 04-25-2009 04:13 AM
boring day/playing with flashes at the kitchen sink khardur Post Your Photos! 11 03-09-2009 12:57 PM
coffee spoon on sink TaoMaas Monthly Photo Contests 0 09-30-2008 05:22 PM
All times are GMT -7. The time now is 04:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
