Originally posted by dugrant153 Hmm... I've been doing some research and sounds like Ilford XP2 Super has some "exposure latitude".
I'm trying out some Kodak BW400CN and will see if it has any at all. From what I've seen, when exposure is off on certain films (especially color ones), the pic is usable but detail is lost and it looks cloudy
But my guess is probably best just to stay with a set ISO and adjust everything else.
Or get that second camera
hi dugrant153
following decades of experience on film, what you have said yourself in the end of your message is the only best solution if you don't want to sacrifice image quality vs for film sensitivity: stick with a fixed ISO and then adjust lighting for the scene.
however, films with a larger exposure latitude, if photographed properly and then processed rightly too, can yield up to 9 stops difference between highlight and lowlight areas of the subject UNDER sufficient light, namely sunlight or well lit sutdio conditions.
and that applies true to most b&w as well as many types of color films.
there were (still are) 'variable ISO' b&w films out there too. using such films you can set the exposure meter of the camera to say ISO 200, but go ahead and shoot almost in any lighting condition and stay assured that everything within a 5 stops ramge of exposure will be recorded correctly, well, almost.
i said "almost" because again, the brighter the scene (say under sunlight) the broader the range of contrast / color shades such an emulsion can capture, without loss of sharpness and grain structure (granualrity) which is different (as well as somewhat weak) in such variable ISO film emulsions, as compared to a regular emulsion with lower exposure latitude yet more evenly distributed grain pattern ...
and last but not least, the most important factor about such films, even 'regular' films, b&w or color, is the processing and chemicals of course, plus darkroom or photo lab techniques and handling expertise, which is a fact that i have noticed even some pro photographers do not pay much attention to.
if you really want the widest spectrum of colors and broadest of exposure latitudes inherent in ANY emulsion, the first thing you HAVE TO avoid would be to leave your exposed film to regular commercial print shops, namely those in the convenience stores or similar places, unless you know they will 'wash' your film using only 'fresh / non-replenished' developer and fixer, as well as you are sure they will handle the film roll just like a new born baby!
i would even go further as to recommend that if a photographer using film material is truly after the best possible quality to come out of his or her hearty efforts, s/he ought to take care of the processing department him or herself just as s/he does it at the photographic stage.
however, achieving desirable high quality results under similar lighting conditions but using digital technology, can of course come in much handier for most photographers these days mainly due to handling issues: film (and chemicals) is much trickier (thus harder and messier) to tackle than digital storage medai due to obvious reasons.
i hope this helps.
