Originally posted by GeneV Can it really be the same for all developers?
That is a good question and I am inclined to doubt it. My old Kodak "B&W Darkroom Data Guide" has a circular slide rule for film development that includes a linear scale for temperature correction that is intended for all Kodak materials available at the time of publication (1979). That slide rule yields temperature correction that reflects a little steeper curve than the Ilford graph or table, but is in the same ball park. Too bad the forum's BB Code implementation does not support tables, but here are some raw comparison numbers:
Ilford Table:- 18C -- 12.30 minutes
- 20C -- 10 minutes
- 22C -- 8 minutes
Kodak Calculator:- 18C -- 11.8 minutes
- 20C -- 10 minutes
- 22C -- 8.4 minutes
Note that the Kodak calculator uses a guide number (linear scale) based on film developer combination to determine the time/temp range. The temperature correction is universal across products for any particular guide number. So the only difference between the Ilford and Kodak calculation is the temp correction factor itself. How that was derived is anybody's guess.
My old Kodak guide is designed for older style emulsions. Looking at the data sheet for Kodak TMax 100 film, it is obvious that different developers require different times at different temps for that material. The same is true for Fuji Acros 100, but to a lesser extent. So...my conclusions about the time/temperature table are that is useful, but your mileage may vary. New style emulsions may not comply. Check first with the product insert and resort to the Ilford table when manufacturer's data is unavailable.
