Originally posted by icywarm Can you over fix
only through a gross display of negligence, Fixer can bleach film if it is left in there for too long. At any rate I prefer to put my film through some hypo clear after fixing and squeegee with distilled water - incidentally, the water you are using to wash the film could also be a source of the milkyness, what is the water quality like in your area? The water here in Adelaide can leave hazy/foggy splotches on film when it dries that can be a PITA to clean of - especially if it gets on the emulsion side.
P.S If a lack of fixing is the problem you can just put the film back in the fixer and it should clear up.
