Originally posted by MattC Just wondering if anyone is using this scanner, and what your thoughts may be regarding the results?
I have read the couple of reviews that are available, but would like some real world feedback - especially if you are scanning b&w.
Thanks,
Matt
Matt - I've been using said scanner for about 6 weeks now. Previous model was a Microtek i800 pro - for about 2 years using Silverfast. Using the stock Scan Gear for now with the 9000 as it is very good, before upgrading - make that IF.
In a nutshell - this could be the BEST scanner out there for the money. I don't think you could spend twice as much to find a better scanner. It simply blows the i800 away - and that's using stock software. The Canon is just so dang easy to use by comparison it actually makes scanning enjoyable - if that's possible.
First - the film holders for medium format are well designed and easy to use. The i800 had really good holders, but stressed the film with the clamping pressure. The 9000 - slip it under the two little ski's at the one end - lay film down flat - click other end - slide film to adjust - done. Even has a gadget to flatten the curled film - which I have not needed.
I shoot allot of Velvia and Kodak - colour and B&W from Acros to Ilford. It had eaten up every one of them flawlessly. I'm re-doing ALL my scans previously done with the i800. Even scanning some of the new Ektar - even without the IT-8 profile used in SF - has been spot on.
The film had a lot of marks and dust from previous uses trying to prevent CA with the i800. The 9000 - NONE - no CA visible whatsoever. The marks and scratches? Used the infra red FARE on low - almost gone. Used medium strength - PERFECT - I mean not a scratch or mote. Best of all - does not affect the image quality. No softening of features.
I've used the optional methods to dial in the scan using the Recommended method. This allows the gamma change, plus Levels and Curves adjustments with saturation before scanning. Excellent results - although a fair amount of work.
What I like best - is the Colour Match method. This uses your monitor profile - be it Adobe1998 or sRGB etc. I use a Mac - so I calibrate the profile, and refine it. Save the profile, and that's what the Canon uses for scanning. The end result can be fine tuned to match the film type or if you use a Calibrating Device.
Each film type is different - so I've created profiles for them. Example is Ektar - with it's reddish characteristics on skin tones - stronger blues over water or at altitudes - I scan - and put that image on the screen. Bring up Calibration software - and fine tune. Scan - tune and when I'm happy with the result - create a Profile - Ektar Adobe1998.
When I'm scanning Ektar film - I invoke that profile - and get my version of Colour Match bang on. I've done the same for Velvia 100 - Velvia 100F - etc, where there is enough difference between the films to create a separate profile.
Why do that - and not just do it post processing? The effort to create a colour match profile means you do it ONCE. Well, a few fine tunes - then you are done. The resulting scan - means little to NO post processing. Sure - crop - adjust Levels a tiny bit to suit. You can basically just clean up to suit and you are done in a couple of minutes unless you have specifics in mind.
Fast - YES. Normal E6 MF 6x7 scan takes less than 1 minute. The Ektar with FARE on medium - took about 3 minutes. B&W - just fabulous scans - but here I use similar created profiles for each type of film - to bring out the nuance of that film ie: Acros vs Delta 100. But I've found the "Recommended" method better where I can fine tune the scan using the histogram and Curves for each shot. This gets the most out of the B&W - night vs day shots etc, then I fine tune post processing for effect. You can also select scan rates with in between settings like 1600 dpi - right up to 9600.
I could go on - but on the recommendation of emails with Mr. D. Brooks - Shutterbug - and his blog write up on it - I bought the Canon - even over the Nikon 8000ED. He basically said - you can have twice the hardware with the Nikon - or twice the resolution with the Canon.
DigiFotoBlog
I also do film astrophotograhy - and this is where I see a difference using Silverfast - my demo version. Using HDR48 at 2400 - and the Two scan method - it does one pass for highlights, and a second for shadow detail - then combines them into a single film - makes a difference. It would also make a difference for various landscape frames under specific lighting conditions.
Best of all - Canon now bundles SF - with the 9000F. I bought mine without SF - delivered for about $200 in Canada. A friend of mine has the Epson 600 - and although similar specifications - thinks the Canon gives cleaner scans especially on difficult lighting - both using stock software.
I recommend getting an extra film holding tray. This thing is so fast - you spend more time fiddle futzing with change over than scanning. Get another tray loaded whilst the first is scanning.
I have not done any photos or tried FARE on them - yet. I've shot slides all my life. But I do have a mountain of family photos to do. I expect no less from the Canon on those.
Hope this helps.
