Originally posted by Ron Boggs I've used the Better Scans variable MF carrier for a different Epson scanner, but same or similar adjustable unit. Enjoyed calibrating it and it works splendidly and is well made. I can recommend it highly, though you'll likely find that the adjustment doesn't make near the difference you had hoped for--but there is some noticeable difference.
Are you using by chance the V700 or 750? I have a 700 and I find that the film sags - or bulges - enough to make a sharp corner to corner scan difficult, to say the least. While I'm scanning mainly for cataloging purposes, a sharp scan would make a fine contact sheet. Are using the ANR glass or the t bars? "Adjustment" is for height, I assume.
Thanks,
George
