Originally posted by jzietman What do you mean by "failed?" The strip feeders' LEDs, which align the negatives, do die after a while, and you can buy a new feeder for $125-$175 on eBay. I can't pony up for that yet, so I'm reduced to scanning frames one by one using the strip adapter in the slide scanning module.
Thanks for the tip regarding the LEDs.
By fail, I mean that it does the AF and exposure read, starts the capture, but throws an error as the scan itself ends. At first, it happened on the 4th or 5th frame on a 5 frame strip. Last night, it was failing on about half of the first frames of a series. Ditto for single frame attempts. I suspect a failure of the scan buffer memory.
