03-25-2011, 11:02 PM   #1
Which fixer?
I can get Ilford Hypam for much cheaper than Kodak Rapid fixer.
Is there a big difference between these two?
03-26-2011, 01:41 AM   #2
Yes. The Kodak's a hardening fixer, the Ilford's not.
"Hardening" means it toughens up the emulsion a bit, so it's more resilient after processing. Whether or not this is relevant with modern films - which are already pretty hard - is probably debatable.
03-26-2011, 05:27 AM   #3
Kodak comes as two separate solutions right?
03-26-2011, 05:42 AM   #4
Nesster's Avatar
You may want to browse through this thread
https://www.pentaxforums.com/forums/film-processing-scanning-darkroom/128047-...o-you-use.html
03-26-2011, 10:00 AM   #5
Wheatfield's Avatar
QuoteOriginally posted by lithos Quote
Manufacturers started prehardening their film emulsions in the 1980s. What heppens now if you use a hardening fixer with film is that you actually make the emulsion easier to scratch.
Best bet is to pick any non hardening fixer, or, in the case of a fixer with a separate hardener, just omit that part of the solution.
And don't fix for more than twice the clearing time with rapid fixers, and when the clearing time has doubled, the fixer is done.
03-26-2011, 10:02 AM   #6
Otis Memorial Pentaxian
I was always taught that the general rule of thumb is to use a hardening fixer unless there is good reason not to (post-fix staining/toning, for example). That being said, there is a fair amount of information on the Web (Google "non-hardening fixer") that offers the opposite advice. Go figure...I guess times have changed.
For my purposes, I use plain old Kodak Fixer (powdered) and re-use once for negatives and wash for 15-20 minutes in a siphon-type film washer with no clearing agent.
BTW...many of the eastern European (Foma, Efke, etc) and "classic" emulsions require a hardening fixer.
03-26-2011, 10:04 AM   #7
...Ha! Ha! You must remember the thread where the user over fixed and washed the image away!
03-26-2011, 10:16 AM   #8
QuoteOriginally posted by Nesster Quote
Oh, yes! The gourmet fixer thread!
film, photography
What fixer do you use? Nesster Film Processing, Scanning, and Darkroom 49 02-11-2011 11:45 AM
How Long for Fixer,StopBath, and Hypo Clear? montezuma Film Processing, Scanning, and Darkroom 7 09-14-2010 06:17 PM
A Real Fixer-Upper rparmar Monthly Photo Contests 0 07-04-2010 01:18 PM
Residue and crystals in fixer? ytterbium Troubleshooting and Beginner Help 5 05-22-2010 12:32 PM
All times are GMT -7. The time now is 03:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
