Originally posted by StefanMikes There's something you guys could help me resolving.
I thought more Mpx simply translated into a larger picture produced with the same output resolution. So 300 dpi print will be larger when you use more MPx. For screen, you won't be able to display more than the screen's resolution (a HD screen needs some 2 Mpx), Now, we are talking on 16, 24, 36 Mpx sensors. Isn't it so that some laws of physics result in worse crop quality if many more pixels are crammed into the same APS-C sensor? There must be some reasons for using full-frame DSLR, right?
Don't over-think this.
More pixels is more pixels. Capture pixels ==> the same pixel dimensions on output.
Quality of pixels is another matter.
If this were the dSLR section of the site we could convert this thread to infinite length by throwing out suggestions of higher quality capture from a larger sensor. Instead, this is the film processing section so we can talk about the quality of scanner optical path and the real-world scan resolution and how they along with technical expertise determine the quality of the scanned image.
