Originally posted by jeztastic ...
I'm still not 100% sure I understand your previous comment about medium format film "increasing the numbers significantly"
There are many different camera formats in medium format each projecting a different size image on a 120 roll of film. For example, there is 6x4.5 (aka 645), 6x6, 6x7, 6x9 and more. These represent the size of the image frame in centimeters. But they are rounded off. Actual frame size is slightly less with the long dimension varying a few millimeters from one camera manufacture to another.
That being said consider a Pentax 6x7, for instance. It's reported image is actually 55x70mm (=2.17x2.76 inches). So if you scan that at 4000 dots per inch (actually its spi but scanning software usually says dpi) you get an image (2.17 * 4000) by (2.76 * 4000) = 8680 x 11040 pixels.
Quote: Anyway, it seems it's still worth my pressing ahead with rigging something with the K10D. If the results are unimpressive, picking up a cheap or second hand 2400dpi scanner is also an option, given that it there is software available to produce RAW files.
It takes really high scanning dpi to get the most out of 135 format (not just for file size but quality of the image too) whereas an inexpensive flatbed scanner does a much better job with medium and large format sizes.
