Originally posted by Todd Adamson LegacyPro 100
See same here Todd.Image here is 100 legacy pushed to 800 iso.
In my case,image is underexposed to begin with,maybe a full stop.
Developed with a 'magic elixar' of 50% D-76 & 50% semi-expired E-6 first developer.
When processed,did so at (believe 71.5f,cant access notes) rather than standard,
for me, 68f.Did get a bit careless extrapolating time.Rather than 'crunching the numbers',
kind of took an arbitrary stab at processing time vs. chemical temperature.
Several years ago,made the decission to never run any B/W above 68f.
Changed my mind,can see what happens here.
To largest extent,believe "poppy got a little sloppy" here, with time vs. temperature.
What really is interesting,is how simular images are when your rodinal
and my "monster mash" are compared.
Am wondering about and not able to pin down other varible(s)...
Aggitation? rotary used here ...maybe too aggresive for temperature
Cross-contanimation? Normally pretty good about cleaning,"stuff happens" though
Developer viability? D-76 mixed close to 5 months.Well sealed,but old none the less.
Used illford rapid fix,always been consistant,easily obtainable for me.But, as with my
D-76,has been 'around' for awhile.Again, a question of viability.
Used a stop bath,white vinagar(5%) dilluted 1:4 with water.Should know better I guess.
Edit: jumping betwix images,anomilies apparent on high lights of both.
