After close inspection of some of my scans, I've noticed problems with horizontal color streaks across my scans. I'm using a Pacific Image Primefilm 7250u scanner. I've emailed them about it, but I haven't heard anything back yet. Here's some examples. They aren't that noticeable, but, if this problem showed up on a DSLR, people would definitely be raging. I have to scan each image about 10 times before I get a scan without these bands. The band itself shows up at different areas across the whole frame, but is usually positioned just above the middle of the frame. Also, strangely, it seems to follow parts of the image (see the image of the pier with the red band). Any ideas how to fix this? Or is this deep in the hardware, warranting a return. Also, if it makes any difference, I'm using Vuescan, and everything including the primefilm driver is up to date.
scan 1 shows the bands, scan 2 is a successful scan, scan 3 is the pier with bands following the lines in the actual picture.
