I knew of the 5 MP version but thought that to be a little rough, it is ca. €60 and this one cost me €81 and just took it on a splitsecond decision, wth if it isn't right
At startup, it flashes 4 options and after a timeout defaults to the first option=instant scanning in the last used mode.
The second option is playback on the device, it starts a slide show of all recorded frames.
The third is setting is the recording mode: 1=color negative, 2=color slide and 3=B&W negative (however no B&W slide...).
The last flashing option to choose during startup is USB-mode which shows the scanner as device on your PC. For copying etc instead of removing the SD cart.
On screen is a realtime scan of what you put into it: you see the film actually move so you can manually decide on the best crop of the frames. A click of a button finalizes the scan in a second or so. Negatives are reversed, slides are WYSIWYG. It also auto balances light but you can override that with +/- 3 steps. The screen is not that fine/sharp, it just shows what you are doing. Sometimes I was afraid results were very dark or that I just blew my shots but viewing the endresults was a relief after all.
The picture above was from a Fuji Superia 200 ISO in a ME Super, the base is indeed orange-ish; so it seems to adjust automatically. I'm not sure if I have such old negatives without this color base so I don't know what it produces. I'll have a look later... It senses the film and activates the digitizer. I tried 110 film but that's too small and it doesn't show up properly.
The one thing I can say for now about the colors is that the overall scanned picture is not as vivid as the original print but I'm convinced that's correctable with software. Nothing to worry about IMHO.
One other remark: after scanning ca. 500 frames and pushing a lot of film through it, some dust particles seem to "stick" to the sensor, they can be moved with the film so I guess some compressed air is needed to fix that.
