Originally posted by adelorenzo
Here are a couple of examples of what I am talking about.. I realize I can correct these in Vuescan or Lightroom but it would be nice to try and get it right on the slides. Both were taken in late-day, overcast lighting conditions.
Hi
I've done a lot of slide shooting, including Provia, under exactly those conditions. The colour cast in your samples goes well beyond what I would expect to see. As well, the contrast is quite high given the lighting conditions.
Therefore it looks to me like part of the problem is scanning. Scanning software left to itself tends to increase contrast and exagerate colour casts in shots of this type. You have to make manual corrections to compensate. Some scanning software has an eyedropper function that allows you adjust neutral tones quite easily. Further corrections can be made in your image editing software. For me colour correction of snow scenes is often a two-stage process- fix the worst of the problem in scanning, then fine-tune in Photoshop.
If you want to use filters, that sort of lighting requires more correction than you get with a skylight filter. I've had good results with a Heliopan KR3. However, there is the risk of image degradation from using a filter. Even the Heliopan produced weird internal reflections in one of my wide lenses.
In extreme cold you can run into interesting complications. For example, when attaching a filter at -40 water vapour from bare hands can freeze on the filter and cause fogging which yu won't notice until it's too late. (sigh)
As light changes during the day and as clould comes and goes, there is no simple fix in terms of one filter fixing eveything.
In my experience colour correction of this sort of probelm is done more effectively through good scanning and image editing practices than through use of warming filters.
Hope this helps.
John
