Originally posted by stevebrot Depends on scan resolution. With a Nikon 9000 ED you can get a true 4000 dpi scan. Do the math for the 645 negative and you will get the number of megapixels.
2.36" x 4000 x 1.77" x 4000 = ~67 megapixels
The actual file size depends on the file format. For lossless formats such as non-compressed TIFF and BMP, the number of megabytes is:
(number of pixels) x (bit depth for each color) x (the number of colors per pixel)/8
Yes, the files are huge. JPEGs are usually smaller depending on the amount of compression applied. Mind you, that is just data. Most of those pixels could be junk. The actual quality depends on the lens and the film and technique.
Thank you for that !
Im strugling to to get my head around it though.
Im thinking now, that Im rather posative that Im getting far more finer detail in prints than I ever did
using my 645 gear. I have big prints for me to compare
images that i took many moons ago on a Bronica ETRS and Bronica RF645 and of course lots from various 35mm. I also know the quality is high enough on the 12 million pixel to outperform the best of lenses and quality in itself rests on the lens. aaagh OK i think ive got it lol.
You say a lot could be junk ! So most likely its actualy mostly junk. The scanner will scan at 4000dpi even if there is nothing to pick up. Ok i understand now.
Im trying hard to wrap my head around this now
In some ways then its a bit meaningless.
Then Im also thinking they are huge files, and that
they will have come from a large surface area thats
applicable to format size. This would hint along the lines
of the possability of creating humungously huge prints
without breaking up even if there isnt as much detail.
Does that sound like a fair summary ?
