There have certainly been enough excellent suggestions for nearly any contingency. I would only add the following:
Make sure there is hardener in the fixer, film can be fixed without it, but it scratches much more easliy.
Using fingers to lightly squeegee the film is fine, make sure they're clean and don't grind it, it's just to remove excess liquid, the sheeting action of the PhotoFlo, or the like will allow the film to dry spot free.
I have read debates for decades about the proper method of agitation and while there are some decidedly bad things you can do, and some that seem based on the stars, the purpose is simply to gently move the developer around, so
whatever you do, do it consistently; I suggest 2 gentle top to bottom agitations every 30 seconds or so.
Try to keep the temperatures of solutions consistent.
Kodak Hypo Clearing Agent, or similar will dramatically reduce wet time.
Resist the urge to peek at the negatives until they are fully fixed!
If you mix D76, or it's Ilford counterpart ID-11, be careful not to use water hotter than indicated or you can degrade the chemistry.
Glass containers can be dangerous if broken, but the brown glass jugs I got from a pharmacy were much nicer than any plastic that I ever used, a lot easier to clean and didn't breathe through its walls.
As long as a thermometer registers the same thing each time and you can read it, it's useful, but I think if you could find a Weston Mirrorband dial thermometer that you would find it much easier to read and highly accurate; little things can mean a lot.
It may be overkill, but I always used double the space, that is, one reel with film on the bottom, one without film above it in a filled double tank.
If you're going to do much of this it would be well worth your while to find some Nikkor stainless steel double tanks, they're
really nice to work with.
Wet sticky film is a dust magnet to end all dust magnets. You can find electric film drying cabinets, but a plastic bag of sufficient depth and width with holes in the bottom hung on a door or wall can be a big help, as can a humid room, but if there is dust you can be assured it will find its way.
Changing bags are nice and you should own one, but if you have a
dark room you'll be a lot happier not stuck in a bag, at least until you're used to what you're doing.
I think it's rather nice that all of these suggestions are pouring in because we want you to be successful. To that end I wish you success as well!
