Here's the complete process I am going to use tomorrow (stand development, 2 reels at a time):
Pre-soak
1x (600cc water) 20° C
Developer
1x (6cc Rodinal, 600cc water) 20° C
Stop Bath
2x (60cc vinegar, 540cc water) 20° C
1x 600cc water 20° C
Fixer
1x (120cc Fixer, 480cc water) 20° C
Wash
2x 600cc water 20° C
1x 600cc destilled water 20° C
Wetting Agent
1x (1,5cc Wetting Agent, 600cc destilled water) 20° C
Preparations
Load the film in total darkness.
Mix developer and other chemicals
1) Pre-soak (1 minute)
Fill the tank with water and let it sit for a minute, then pour it out.
2) Developer (60 minutes) (Pushed films, increase time)
Pour the diluted developer into the tank, don’t do it slowly, but don’t do it so fast that you cause the tank to overflow. Once you’ve finished pouring, start your timer and put the push-cap on the tank.
Agitate very gently (making sure to completely invert the tank) for one minute, slow inversions, maybe 20 in 60 secs, bang it sharply three times to dislodge bubbles - very important!
DO NOT TOUCH for 59 minutes, a couple minutes extra will not harm anything (the DO NOT TOUCH is very, very important)
3) Stop bath (1-3 minutes)
Fill the tank up and agitate it 5-6 times and dump it out. Repeat twice (3 times in total).
4) Fixer (5-10 minutes)
Pour it in the same way as the developer, agitate it for ten seconds, then again for ten seconds every minute.
5) Wash (5-15 minutes)
After it’s been fixed, the film can be safely exposed to light. Unscrew the top of the tank and set it aside, pull the reels out and take a look at the film to make sure everything went okay, if your film has a slightly purple tint; this is normal. If it looks excessively purple you might need to fix it a bit longer. Otherwise, put the reels back in the tank and you’re ready to wash.
Fill the spiral tank with water and invert it 5 times and drain the water away.
Refill again, invert the tank 10 times and drain the water away.
Refill one last time, now with destilled water, and invert the tank twenty times and drain the water away.
6) Wetting agent (1 minute)
Dump any remaining water out of the tank. Pour the wetting agent into the bottom and then fill with destilled water slowly until the reels are submerged. It may foam a little; if it does, tap the sides of the tank to shake any bubbles off the surface of your film. Leave it for 30 seconds, then pour everything out and take out the reels.
Don’t rinse!
7) Dry (2-8 hours)
Once you are finished rinsing, take the film out, hang it up, and let it dry thoroughly.
Twist the reel apart and lift one half of it off. Carefully pinch one end of the roll (where there’s no exposures) and lift the film off the reel, letting it unfurl.
Don’t let it touch the ground or anything else. Anywhere dry and relatively dust-free will work fine, but I recommended hanging it up in your shower since it’s out of the way.
Once it’s up, leave it for 2 to 8 hours so it has time to dry and harden completely.
For the stiring when mixing the chems, I've found a hard-plastic spatula kind of thing that will work just fine.
Any comments?
