Silverfast is a scanner driver, not a photo editing program, but it does have reasonably powerful adjustment features that will reduce the amount of PP needed on your scan. I always use it in preference to the Epson software, as it gives good, linear results more readily than the Epson, which frustrates me by always tweaking the scan in mysterious ways that need to be turned off before you start. It is possible that the Epson driver can give just as good results, but I haven't found out how!
Historically, Silverfast's achilles heel has been its ugly, impenetrable interface. Try and make sure you get version 8 with your new scanner (it may come as a free upgrade after purchase). The results are reputedly the same, but the overall experience is much better.
