Can Pentax Slide Copier do the job of a cheap flatbed scanner?
Trying to improve the fidelity of my first try yesterday
I worked out how to reverse the SMC Pentax 1:2.0 55mm in the bellows
Changed the body from M4/3 to ist ds
iso 400 f/5.6 pointing the slide copier at the blue sky
Reversed the neg so the dull side faces the camera
In Gimp:
Flip image, invert grayscale
De gamma of 1.33 for Tmax 400
Unsharp mask of 8, level 1.5
Fidelity is getting closer
https://www.box.com/s/1122137e5e76c4faa561
It is a crop because the 55mm can't reduce the image size to fit the sensor
I don't have a 50 mm macro here which I read is sharper across the plane than a conventional reversed lens.
But I have a Rodenstock Rogonar S 1:2.8 50 mm. Some tests with this lens reversed on the enlarger show this will match all: FF, the aps-c, and m4/3.
So I might go ahead and machine up 2 adaptors for the Rogonar to the Pentax Bellows set, also a bigger focussing knob for the Bellows.
I am focussing with the Pentax Magnifier M and actually I think getting focus is the limiting factor now.
