07-18-2012, 08:59 PM   #16
average-guy's Avatar
I've been using my Epson V500 running Vuescan on Debian. I had to do the same searching that tlong423 did. A quick Google search and visit to a couple of forums and I was set and it has worked flawlessly since.
07-19-2012, 11:45 PM   #17
Can the Epson V600 scan 35mm slides as well?
Jack
07-20-2012, 07:01 AM   #18
tlong423's Avatar
QuoteOriginally posted by jbinpg Quote
Jack
Essentially yes -- but they would have to be unmounted as the carrier is for film strips.
07-20-2012, 06:01 PM   #19
Ah, thanks. Quite a bother for Kodachrome.
07-21-2012, 02:07 PM   #20
QuoteOriginally posted by tlong423 Quote
Wow, that stinks, that's one more reason to keep my V500. It's carrier allows you to scan mounted slides.
Edit: I just had a thought, can the V500 negative/slide holders be used on the V600? If so that could be an option.
07-22-2012, 09:24 AM   #21
Otis Memorial Pentaxian
QuoteOriginally posted by average-guy Quote
The V600 ships with a slide carrier...at least it did when this review was written...
Epson V600 Photo Review
The 35mm holder does double duty for both slides and negative strips.
07-23-2012, 09:07 AM   #22
You're right, If the review is showing the correct photo's the transparency holders for the V600 are identical to the V500 holders. So mounted slides shouldn't be a problem.
07-23-2012, 03:40 PM   #23
Thanks, guys.
Jack
film, photography
Good cheap negative scanner ? spystyle Film Processing, Scanning, and Darkroom 23 05-12-2012 05:39 AM
Enlarger lens replacement and linux scanner for 35 mm wombat2go Film Processing, Scanning, and Darkroom 27 12-02-2011 09:47 AM
Processing RAW files in Linux (Ubuntu) krishna Troubleshooting and Beginner Help 9 04-23-2010 10:58 PM
Linux -- Ubuntu Karmic 9.10, libraw 0.8.5, Raw file processing K7er Digital Processing, Software, and Printing 4 01-13-2010 08:35 PM
Linux Workflow (Ubuntu) disasm Digital Processing, Software, and Printing 21 08-01-2009 01:16 PM
All times are GMT -7. The time now is 12:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
