Originally posted by bobpur Hi
I have done hundreds of negatives, color and B&W. A lot of different sizes, many of my Grandfathers from the 1st War.
The easiest is to make a simple light box with a compact flourescent lamp, a glass plate with a piece of white paper for a diffuser and another piece of glass to
hold down the Neg.
Set up the camera with a Macro lens or a lens and a macro filter, even a lens with an extension tube will do on a tripod.
If you have live view it is even better.
Just set up so the neg fills the viewfinder and shoot using the 2 sec delay or use a remote.
Once the focus is set it is just like a production line and faster than a scanner.
Use just about any pic software to change to a pos image. Crop and adjust if necessary.
This is interesting. How would a capture like this using a K-5 on low ISO compare to an Epson V750.... assuming a 120 color negative? Say I'm shooting with a DFA 50mm 2.8 macro.... would it be similar?
