07-27-2012, 03:03 AM   #1
Scanner 4 120
Good morning to all,
I would buy a scanner for film 120, between the different models I noticed that the 9000 F Canon is very good. I wonder if anyone has ever used it? I wonder if you could help me? You know models in similar price?
Thanks a lot
Giorgio
PS
Sorry for my English
07-27-2012, 12:01 PM   #2
klaus123's Avatar
Hello
I use it for ~2 years meanwhile - for 645 or 67 it is great - usually I scan 2400 dpi - quality can be slightly increased by using an anti-newton glas instead of the original negative holder
https://www.pentaxforums.com/forums/film-processing-scanning-darkroom/180040-...ocus-film.html
07-28-2012, 02:09 AM   #3
hollywoodfred's Avatar
Giorgio, I purchased a 9000F about eight months ago, and I have scanned only about 100 negatives for my personal use. Most of the negatives were 55 year old 120 format in black and white. I'm pretty happy with the results. I use the software that was bundled with the scanner, and using the original negative holder, I am able to scan three negatives at a time.
Fred
07-28-2012, 08:13 PM   #4
I use the Epson V600 on MF. It takes four frames at once.
Slow but they all are.
07-30-2012, 12:13 AM   #5
Thank you all!!!
I want to know how much detail is lost in the transition between film to digital format? I would like to print 50x50 cm (I use yashica 124 g mat).This can be done?
Thank you for the answer !
07-30-2012, 03:30 AM   #6
I haven't attempted to print anything as large as 50cm, so no personal experience here. But searching this forum, I found a thread that may be helpful to you: https://www.pentaxforums.com/forums/film-processing-scanning-darkroom/142139-...-confused.html
07-30-2012, 05:13 AM   #7
Thak you for the Help!
I need a scanner for two use. The first use is in the blog, the second use is a portfolio.
07-31-2012, 01:19 PM   #8
artobest's Avatar
I have a Yashica 124G. I scan frames with an Epson V750. 50cm prints are no problem for me with these scans! The detail is incredible.
film, models, photography, scanner, wonder
Problem scanning 120 negs...scanner cuts images up. slackercruster Film Processing, Scanning, and Darkroom 9 07-12-2012 02:33 PM
Reasonable priced scanner for 35mm, 110, 126, 120 Colbyt Film Processing, Scanning, and Darkroom 21 04-11-2011 08:27 AM
How good is a Microtek 120 TF MF scanner? Sig M9 Film Processing, Scanning, and Darkroom 5 01-03-2011 11:36 AM
Recommendation for scanner for 35mm and MF with 120/220 hinman Digital Processing, Software, and Printing 26 02-12-2010 12:24 PM
All times are GMT -7. The time now is 09:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
