Originally posted by grainbelt I'd have to trick it into scanning as one image and manually crop each one. Hundreds of times.
Originally posted by wildman I tried this method on my Epson V600. I didn't find it a big deal to do it this way. I can specify the size of the crop marquee to exactly what I want and set it over multiple images.
I've scanned around 25 110 neg. with the CanoScan 9000F, with this strategie : preview the scan area, then select each "area" of each picture manually (with a selection a bit bigger than what i really want), scan.
While you scan new pictures, you can crop the pictures already scanned.
I do that with 135 films, take me around 30min to scan, crop, and tweak every picture for 36 exposure.
(My scanner take 2*6 frames in 135. With 110 count that you can do probably 20 frames per scanning, i guess.)
Remember that before putting the film in the scanned, take a look at the neg. to make sure you don't scan picture that are useless like totally burned one, of blurry, etc ... You will gain lots of time.
If you plan to digitalize a lot of picture, scanner can be a good option. Specially if you have multiple format like 110 / 120 / 135.
