Originally posted by Bob from Aus 1. There are many different kinds of slide magazines. make sure the globe still works before you invest in magazines. If you replace the globe which can be expensive make sure it is the correct amps or you can damage the projector.
2. Any Agfa slides will be on the way out - they go downhill badly after 20 years. The Kodak are probably fine. Tropics are a killer with heat and humidity. Low humidity storage if possible is best and this is often in a cupboard. The projector does the most damage in my experience.
3. I have never found a good system for cleaning slides.
Projector is still in 100% working order, globe works, image can be correctly focussed when a slide is manually slid into the slot, when the remote is pressed the slide carrier thing moves in and out correctly (but not having a magazing I can't check it advances properly)
Most of the slides seem to still be ok, there's a few discoloured and faded ones, but overall they seem quite good.
Granted, there's many I haven;t checked (there's easily over a thousand slides) but many of them are historically important, either for us (being pictures of my gf's family) but there's also many many images from Lakeside raceway when it was built, and many other historic QLD landmarks.
Luckily for storage they're now located in Victoria, away from the humidity and heat of QLD.
