Originally posted by jt_cph_dk - I could make a 6400ppi scan and downsample to see the difference (I´m not sure what you mean with the ‘technique discussed here‘?). I haven´t ckecked in a loupe.
- I can see why you aren´t happy with your scanner. It´s really not sharp. The B&W scan crop posted by you here first, at the top looks better.
But the Ektar has really, really fine grain in this version
- With the "technique discussed here" I intended the use of a digital camera + multishot.
- Not "my" scanner anymore, after I saw the results of using the Canon I dumped it in the *bay
You're referring to the b/w example. Now maybe I'm crazy, or maybe it depended in same strange way by the kind of contrast those negative had, but the Epson actually performed this good only with Adox 25 negatives (b/w) shot with an Hasselblad + 80mm Planar. The same negatives, developed in the same tank at the same time, but shot on a Pentax 67 weren't scanned as good, even though they were equally sharper - I checked with a 22x loupe. And you just saw what junk my 700v made of the Ektar shot with the same Hassy and the same lens
