12-23-2012, 08:42 AM   #1
germar's Avatar
How am I causing this emulsion damage?
Hi, all....
I'm newly returned to film development and I've gone through a small handful of 120 film. I've noted I'm causing some sort of emulsion damage on my images, and I'm not sure how. Is it possible to do this during the dry phase of loading the film onto the reel, or is this something that happens when wet? I use a plastic reel and I often carefully split the reel so I can pull up and unwind the film when the final wash is over. Or could I be doing this when I "squeegee" the film between my index and middle finger? Any ideas would be appreciated ... it's not every frame, but enough to know I'm clearly doing something wrong. Thanks in advance for any ideas.
12-23-2012, 05:13 PM   #2
If you scratch the film during loading, that could cause damage. Also, if the developer isn't distributed evenly, that might lead to some imprefections as well. Once the film is developed I don't think squeegying will cause any damage, but I usually hang the film up to dry instead.
12-24-2012, 04:57 AM   #3
artobest's Avatar
Squeegeeing is risky. I never squeegee with fingers or anything else - a bit of wetting agent in the final mix and the water slides off leaving no mark.
12-24-2012, 09:38 AM   #4
germar's Avatar
Problem solved
Thanks both and I will follow your advice on squee-gee use. Hey, I found out what the issue was! I was studying the frames that showed the damage (I have others not posted here) and realized ... the damage is in the exact same spot on each frame! It looks the same as well. It's not the film, I've got a tiny scratch on the scanner glass!
This old Canon 8400F is about to be replaced by an Epson V700, so I believe my problem is solved. The other lesson learned: don't let family members scan documents with staples on the same device you plan to scan your negatives!
12-25-2012, 12:03 AM   #5
You don't need to do that "squeegee" thing with your fingers at all. Developer not "distributed evenly"? LOL.
12-28-2012, 07:59 PM   #6
Otis Memorial Pentaxian
What he said...only LLAL...
12-28-2012, 10:38 PM   #7
I will add the most likely thing that comes to my mind with emulsion damage like that is grit, dirt, sand or something like that in the film transport area. I go to the sand dunes often to take shots. Changing film in the windy, sand blowing conditions gets sand everywhere. I have had similar emulsion scratches like yours but to smaller degree after visiting those sand dunes. So check your film transport area and blow it out as a first step.
12-29-2012, 08:44 PM   #8
See above comments...the "scratch" is artifact from the scanner bed. The negative is unmarked.
emulsion, film, ideas, photography, reel
Am I a Nerd if I Want this Camera? builttospill Pentax Film SLR Discussion 11 06-29-2012 05:28 AM
Am I confused or did I just about steal this A 35mm F2? PPPPPP42 Pentax SLR Lens Discussion 25 04-02-2012 07:26 AM
I'm a left eye shooter - how much am I missing? mike.hiran Photographic Technique 37 02-08-2012 11:13 AM
i can't believe i am asking this after so many years dominikkolendo Troubleshooting and Beginner Help 30 02-02-2012 12:21 PM
Why am I so Anal about How Many Pixels I Have benjikan Photographic Technique 41 05-14-2011 06:41 AM
All times are GMT -7. The time now is 12:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
