The System 4 tanks have two lids. My guess is that the problem is not with the snap on outer lid, but the inner lid that locks in place using a bayonet type system. If the bayonet is not properly engaged there can be some light leakage.
Either that or you may have a light leak in the room where you are loading the tank.
In any case the problem looks much more like light fogging than uneven development to me. Uneven development would not cause the film edge to be dark on one side in the way that it is in the first example. That is much more likely the result of light striking the film from a leak fairly close to the film.
The extent and pattern of the fogging indicates to me that the damage is probably not happening in camera or as the result of a leaking cassette light trap. Assuming that you are using preloaded cassettes rather than bulk loading, that leaves only the tank loading and processing stages where that degree of fogging could occur.
If you are bulk loading, the problem looks very much like damage from opening the access door on the loader without closing the light trap.
That's my educated guess based on having screwed up in just about every possible way over a 40 year period.
(I've also used the older version of the Patterson tank with the screw on lid, which I prefer.)
