Originally posted by aurele Hello everyone !
Just finish processing my first roll
Kodak T max 400 @1600
It's drying in my bathroom.
Congratulations, and welcome to the club!
Originally posted by aurele I developped (with T-MAx) the right time but sometimes i missed the 30sec shaking, and did it @45sec, then 20 sec later than i ratook the right timing.
-> Any consequences ?
Agitation is an imprecise knowledge. It depends on a lot of factors, including your movements and the result you desire. Agitate too often, and the DR will suffer, too rarely and the dev time will be off.
I don't know the proper time for developing T-max 400 @ 1600 in whatever developer you used, but I'm guessing over 12 minutes, which is when I usually only agitate once every 90 seconds or so.
Originally posted by aurele i used the stop bath around 1 min instead of 10 sec (had hard time getting 20°C water sometimes)
-> any consequences ?
Shouldn't be a problem. The purpose of the stop bath is for the development process to stop. It shouldn't interfere with the rest of the process.
Originally posted by aurele I used the fixing bath (all ilford now) for 6min 30sec instead of the 2-5 min recommended, it was purple when i empty the tank
That's probably better. I've only developed T-MAX a few times, but if it is indeed the purple one, I recall that the fixing process is harder and takes longer than for your average film base. It's hard to overfix BW negs if you do it for less than a few hours. If anything, 6min30sec is too little. I'll usually fix for at least ten minutes, and for a difficult film, 14 or so, but it of course depends on your fixer liquid.
Originally posted by aurele I made a mistake and used ilford washaid directly instead of using water first for a first washing, then using washaid. After i did water in the tank, 20 shakes, empty it, replenish it, 40 shakes, again, 60 shakes. a little bit of running water (maybe 1 or 2 min.
As long as you get your film clean of chemicals, it's fine, but you may have exposed your washaid liquid to unwanted chemicals, wearing it out slightly more than necessary.
Originally posted by aurele Should i expect some kind of variation over time on the neg ?
No, under normal circumstances, the film should respond the same over all the images.
Originally posted by aurele I also realise that the last pictures (placed at the "heart" of the tank) where almost all black, does the fact that it was -5°C did have any influence on the ability of the film to react with light ?
You mean that it was -5 when taking the pictures? No, it shouldn't matter that much. The darkening is either incorrect exposure (meter, shutter or reciprocity failure), incorrect development (agitation perhaps, film-to-film contact on the spiral) or incorrect fixing (the same).
Originally posted by aurele one more question : it seems that the end of the film is not "see through", but when i bring the film to light i found some picture.
Should i put this part in some fixer again ?
It's worth a shot. Poor transparency can be the result of underfixing.
I hope that helps. Just what I've picked up in toying around with this stuff.
