Originally posted by Miguel Good luck on that, especially working with 135mm format materials (you didn't specify what your requirement is, so I'm assuming 135 film here) and not involving a drum scanning interface.
Actually, I did.
Originally posted by Racer X 69 So can anyone lead me in the right direction to a scanner that is reasonably priced, that will produce scanned copies of my 35mm slides and negatives, without a whole bunch of fuss?
Originally posted by Miguel You also mentioned reasonable costs which is ambiguous. What is your budget?
I guess that reasonable to me would be somewhere South of $200 to $300.
Originally posted by Racer X 69 I want something that will produce results equal to or better than my digital camera gives me. I don't need assembly line speed or automated results popping out copies at 2,000 pictures a minute.
Surely there is something available that will produce a copy of a 35mm slide or negative with the same image quality and detail that can be had using a digital camera that doesn't involve using a copy setup like this:
Then again, maybe that is the avenue I should pursue. I have seen the bellows setups going for about $150 or so. All a person would need to do is set up decent lighting, and a way to quickly and accurately insert and remove the slides or negatives. Once the focus is set it shouldn't change from one shot to the next, so after getting the exposure set up the process should go easily.
Originally posted by twitch I use a Plustek 7600 and can highly recommend it (or the 7400 or the 8**** series) for your needs. It's not super fast but it does a fantastic job of producing quality scans. My 2c is that the IR dust/scratch reduction feature is not worth paying extra for.
That is one brand I have looked at. How is it for speed? The specs on the Plustek webpage sound pretty fast.
Originally posted by twitch Here's a couple of scans from it:
The images you posted here look pretty good. Are they from 35mm slides or negatives?
Originally posted by amoringello I have the Epson V500. Its a few years old, but it has slide attachment for 35mm, as well as some medium and other formats.
I separates a row of slides into individual photos.
That is a bit like the flatbed scanner I have now, but mine only does one slide or negative at a time.
Originally posted by amoringello Sadly, the software is like something written over the weekend by a first year high school intern.
For every scan, you need to re-adjust the settings for color balance. It takes two to three scans for each set. The software is non-intuitive and difficult to use.
I feel your pain.
Originally posted by amoringello Most advanced features like scratch fixing and whatever "ICE" is, are useless.
I spent two days scanning a few dozen medium format slides and am now looking into spending another several hundred dollars to just have someone else do it for me!!!!
I want to avoid that. Since there are many images that are not worth using, I don't want to pay for wholesale conversion, and wind up paying for converting shots that I would not print in the first place.
Originally posted by amoringello Unfortunately, that seems to be a common issue with most scanners. At least those under $1K. They have great features, and produce nice results... but the software is so G.D. abysmal that you just want to throw it out the window.
My experience with just about all the TWAIN interfaces has been like this. The preview windows are usually too small, and can't be resized. Some offer the ability to zoom in and out, but they are cumbersome, and often don't have the little hand for grabbing the preview image to move around quickly, and zooming with some is by clicking, with each click only changing the zoom level just a tiny bit.
And the preview window with the one I am currently struggling with doesn't even show a true representation of the final result. I can only see what I get after waiting for the bulb to warm up, then preview (in the tiny window) then scan, and wait, and wait, and wait, and wait . . . . .
Originally posted by amoringello All I can say, is if you buy a scanner, be sure you can return it if it doesn't fit your needs. And be prepared to try a few of them.
Hopefully someone has a good suggestion and you can bypass the trial and error phase.
That is why I mentioned this in my original post:
Originally posted by Racer X 69 And surely some of you have already gone through the trial and error process of wading through the myriad choices offered today.
Originally posted by amoringello If you don't need long term use, or if you have less than 1000 negatives, you might look into scanning services.Dunno what 135 negatives will run though. But it might be worth the lack of migraines of the crap passed off with today's scanners.
Again, I am reluctant to package up my slides and negatives, and ship them off somewhere, where I have no control over the process, only to find that I have paid someone to digitize stuff that I might have not bothered with myself.
Thank you fellow Pentaxians for your comments and suggestions, it has been helpful!
