Originally posted by stevebrot So is there some lead foil in the bag somewhere? The item description just says nylon with extra heavy lining. So what happens when they see this opaque rectangle in your bag?
Honestly?
They turn up, and up, and up the power of the X-ray machine, and run the bag with it through several times, thereby increasing the total dosage that it'll get. Pray that the bag is sufficiently shielded.
A MUCH wiser approach is to ask for hand inspection of the film - the trick that works, even with the backwards TSA-thugs, is to say "technical photography, hand-inspection required", and keep the film in something easy to inspect, like a transparent plastic bag.
Speaking from experience....I spend more time in airports and airplanes than what's considered sane.
