Originally posted by stevebrot Are these from 35mm negatives or from medium/large format?
35mm. Yes, I know a lot of people say the V700 is no good for 35mm, but that hasn't been my experience. There are some odd inconsistencies in V700 performance that make me wonder about manufacturing tolerances, but I've been able to pull of pretty good results.
I used to do a lot of work with an LS8000 with glass film holders. The same images scanned on my V700 require somewhat more sharpening at a radius of 3 pixels or smaller when working at an output resolution of 300 ppi for 16x24 images, but the final prints are very, very close.
Some of my methods are a little different from accepted "wisdom". For example, I scan at 6400 ppi. It is quite true that the V700 does not resolve 6400 or even 4000 ppi. However, I would say that my unit does a little better than the 2400 stated by a lot of people.
Scanning at 6400 avoids grain aliasing. It also seems to pick up some information that translates to a better rendering of grain than I am able to achieve at lower resolutions. Part of the process involves careful sharpening in several stages in Photoshop- not in the scanning software. I've arrived at this method after considerable testing.
I do have a fairly powerful computer and lots of storage, so working with extremely large files is not an issue.
I would not use the V700 for critical work- for example, master copies of negatives of significant historical value (I did that sort of thing for 20 years.) However, for pleasing scans of 35mm where convincing but not perfect rendering of grain is acceptable, the V700 has served me well for about 6 years.
These days I'm concentrating on scanning a large number of my medium format images, going back to the early 1980s. Once I've finished that job, probably in a year or two, I'll look at what is available for dedicated 35mm scanners. The V700 may be worn out by then...
