Originally posted by whojammyflip This is interesting. Nice post.
The 5D can see 21x10^6 pixels. This works out as 150 pixels per mm, which in turn is 75lp/mm. I doubt the Epson can see more than about 25lp/mm. Sharpening etc doesn't add anything to the resolution, it just increases the apparent contrast of low frequency details.
Decent film, shot through a sharp normal, like the 80mm (I've got a Bronica and saw a test on line for PE lenses, Hasselblad and Mamiya, and I seem to remember the Mamiya glass was highly rated) will reach 100lp/mm. There are Zeiss docs online recording 400lp/mm, but this is unlikely unless you have awesome film and glass, shot with specific lighting conditions etc. But 100lp/mm is feasible.
The fact that neither the 5D nor the Epson hit 100lp/mm means that they need to look at an enlarged section of the negative and then have it stitched together. The Epson cannot do this.
If you look at this link:
http://www.addicted2light.com/2012/11/23/best-film-scanner-canon-5d-mark-ii-...vs-epson-v700/
its clear that the stitched 5D scans exceed the Epson by a long way.
Some interesting observations and info here. I agree with much of what you say. The tests I have shown suggest that with this particular negative, a small amount of very fine detail is not being captured at 1:1 magnification with the 5D II, and therefore a slightly higher magnification would need to be used in order to capture this, requiring the stitching of more shots to get a complete frame. Finer grained film like Ilford Delta would certainly need a significantly higher magnification to capture all available detail.
The examples and comparisons shown on the link you give are, based on my own observations, misleading however. Information given about how the examples were produced is quite sketchy and in some cases, contradictory, making it difficult to draw reliable conclusions from them. For example in the first comparison - the black and white crop with the rocks, the shooting magnification of the camera shots or scanning resolution are not given.
Based on my own experience, I would say that the 5D image was shot at a magnification approaching 1:1 which would require several stitched shots to cover the whole frame. Also the scan does not appear to match the quality I get from my V700. As can be seen from my example given above, the scanner is capable of capturing a reasonable impression of the film grain, whereas here the grain is completely smeared away. So I think the examples on the linked page overplay the difference between the two methods substantially. Of course it's possible to get far higher quality by using a camera at very high magnification than a consumer flatbed scanner. But the higher the magnification, the more shots have to be produced, manipulated and stitched, which is a very lengthy process if you want to do a good job. Comparing like with like (ie. a single scan versus a single camera shot), the V700 (or at least my copy) certainly out-resolves the 5D II when copying a 645 frame.
---------- Post added 02-26-14 at 07:40 PM ----------
Originally posted by Jens Lyn IV I just had to try this, but I don't have a light box, or a negative carrier, or even a flash. So I set up my tripod in front of the desk, put a flat white image on the pc monitor and cranked up the brightness, and suspended the film between The Lord of the Rings and The Silmarillion using rubber bands. This ghetto setup worked surprisingly well, and in many ways the result compares favourably with my developer's scans. Oh, and I managed to enhance the negative with a big fat greasy fingerprint after the experiment...
From top to bottom:
1. Whole frame from DSLR
2. 100% crop of scan
3. DSLR crop scaled to match scan
4. 100% DSLR crop
The scan shows obvious macroblocking; I don't know if they are compression artifacts (1.5 MB JPEG) or some scanner idiosyncracy. The DLSR version is very soft, but compared to the scan it looks much more pleasant up close. I may have missed focus, something may have moved during the 1-second exposure, and/or the focal plane may not have been parallel to the film plane - I suspect all three.
The film is Ilford Pan F Plus exposed in an Olympus OM-10. According to the EXIF data, the scanner is a Noritsu QSS-32 or QSS-33 (listed as "NORITSU KOKI QSS-32_33"). Raw file from Pentax K-5 with SMC D-FA 100mm WR. Coarse lighting adjustments and monochrome conversion in PDCU. Inverted, cropped, and compressed in GIMP.
Jens Lyn, this is a good effort considering the equipment you had to work with. Your shot is clearly a lot better than the commercial scan. It might look softer but there's far more detail from the film in it. I'm surprised you managed to capture so much of the grain with a K5 and a fine-grained film like Pan F. Did you shoot the whole film frame or just a portion at the maximum magnification of the lens (1:1)?
