When I was younger I learned how to use cameras and take photos, I learned on film.
Dad for a few years had a darkroom setup at our place where he originally developed Black and White, and after a few years of that he and a friend decided to share costs in converting the darkroom to process colour. They were avid motorsport photographers and would often be caught sneaking into the restricted areas of the Grand Prix.
Fast forward many years later and after my basically cracking the shits with digital I decided to get back into film, and I’m loving it. Film seems to attract more people interested in the image and the art over the technology (sorry, but digital discussions often seem to just end up as a megapixel dick measuring contest)
So, now having converted to about an 80/20 mix of Film/digital I’ve decided to build a darkroom and make use of dad’s kit (he was rapt that it’s being used) so far I’m only going to do black and white, dad needs to talk to his friend about what he wants to do with the colour gear, and most of it’s all useless now anyway (dad always worked with Cibachrome, he preferred the positive to positive process)
Now, the darkroom itself has some design criteria to fit my needs.
It must be cheap – I’m a cheapskate, plus money’s usually tight anyway.
It must be discrete – Discrete means security, and also means the landlord doesn’t get annoyed (rental)
It must be removable – since it’s a rented house, I can’t go banging nails into the walls.
It must be compact – the space I will be utilizing isn’t large.
I’ve chosen to build the darkroom inside the back garage, it’s quiet, it’s already wired for power, and it’s in pretty rough shape already (meaning I don’t need to be as concerned about damage)
It does however have a leaky roof, and no running water.
The plan is to build a “room within a room” making a completely separate floor/walls/roof so that the darkroom requires no structural changes to the existing garage beyond simply resting it upon the existing floor.
In this thread I’m going to try to cover everything from this post (the idea) through the design, to the actual building.
I do warn beforehand though, it won’t be a fast process. Progress will happen as parts and budget permit (I will be trying to re-purpose as much as I can as far as materials go)
