01-26-2014, 12:15 PM   #1
smithdoor's Avatar
Resolving for film ????
This looks right ????
Dave
T-Max 100
200 lp/mm
35mm film
PX CALC Logo - Get to know your screen
Enter the specs of your screen
Resolution
Horizontal Pixels 5000 x 7000
by
Vertical Pixels
Diagonal Size
Inches (4.3cm)
Design in life size. Design for life.™
When you zoom to 100% in programs like Photoshop or Illustrator you're not actually seeing true print size, but if you know your monitor's DPI (dots per inch), also known as PPI (pixels per inch), you can work around this.
Your screen’s info
DPI: 5081.11
Dot Pitch: 0.005mm
Size: 0.98" × 1.38" (2.5cm × 3.5cm)
Aspect Ratio: 5 × 7 (0.71:1)
Pixel Count: 35,000,000
Megapixels: 35MP
For 4 x 5
Resolution
Horizontal Pixels 10160 x by 1270 Vertical Pixels
Diagonal Size
Resolution
Horizontal Pixels x
by
Vertical Pixels
Diagonal Size
Inches (16.26cm)
Your screen’s info
DPI: 5080.1
Dot Pitch: 0.005mm
Size: 4" × 5" (10.16cm × 12.7cm)
Aspect Ratio: 4 × 5 (0.8:1)
Pixel Count: 516,128,000
Megapixels: 516.13MP
Minolta-16 13 × 17
Resolution
Horizontal Pixels 2600 x 3400 by Vertical Pixels
Diagonal Size Inches (2.06cm)
Your screen’s info
DPI: 5277.67
Dot Pitch: 0.0048mm
Size: 0.49" × 0.64" (1.25cm × 1.64cm)
Aspect Ratio: 13 × 17 (0.76:1)
Pixel Count: 8,840,000
Megapixels: 8.84MP
01-26-2014, 12:57 PM   #2
Kodak's MTF chart for 100TMX shows around 150 lp/mm at 30% contrast. Where are you getting 200 lp/mm from? And how may 4x5 lenses resolve over 80 lp/mm, I wonder. And then there the many variables like flim flatness, etc.
01-26-2014, 05:25 PM   #3
smithdoor's Avatar
From Kodak book 200 lp/mm I think was print 1970's or 1980's
Dave
01-26-2014, 05:31 PM   #4
QuoteOriginally posted by smithdoor Quote
Dave
Kodak has all their film data sheets online. 100TMX today is a different formulation than 20 years ago, for instance. Can't say what effect that has on the film's resolving power.
http://www.kodak.com/global/en/professional/support/techPubs/f4016/f4016.pdf
01-26-2014, 05:41 PM   #5
smithdoor's Avatar
On page 13 from Kodak
KODAK
PROFESSIONAL
Film
Resolving Power* Diffuse rms
T-MAX 100
63 lines/mm (TOC 1.6:1) Granularity† 8
200 lines/mm (TOC 1000:1)
T-MAX 400
50 lines/mm (TOC 1.6:1) Granularity† 11
125 lines/mm(TOC 1000:1)
Dave
01-27-2014, 04:49 AM   #6
T-Max 100
200 lp/mm
Quick question:
Acuity defined this way (lines per mm) anyone know what is the acuity of a 20/20 normal human eye at say about 1.5-2.0 feet under "normal" lighting?
01-27-2014, 06:07 AM   #7
smithdoor's Avatar
QuoteOriginally posted by wildman Quote
Quick question:
Some can go down to 0.005 after than you need
As photos go closer to 0.010 most news print 80 line per inch metric is 3.15 lp/mm screen or 0.0125" and metric is .3175mm this also works for digital cameras
for printing in to Digital take a lot of pix to change the colors.
I started researching this because 40 years ago I was enlarging 35mm to 16x20 prints using TRI X and PAN X film I also made enlargement on the wall around 30 to 1 and work too.
Try to do this with digital and found enlarging to size did not work. Also tried to enlarge just part of digital photo did not work will.
So was trying find how many pixels will take to do the same photo in digital find number between film type/ASA and digital pixe
l
Dave
Dave
01-27-2014, 08:03 AM   #8
Tom S.'s Avatar
Thread moved. General Talk is for non photographic related topics only.
02-25-2014, 01:37 PM   #9
Dave
I guess my EL-Nikkor enlarger lens must be worse than I thought. Because enlarging 35mm Tri-X to 16x20 produced really grainy images and poor tonal scale (strecthing the grain apart ) compared to my 120 roll film, 4x5 sheet and 36MP digital camera.
02-25-2014, 05:06 PM   #10
ChrisPlatt's Avatar
Panatomic X was terrific. Sure wish we still had it to use today...
Chris
02-25-2014, 07:47 PM   #11
QuoteOriginally posted by ChrisPlatt Quote
Chris
I still have about 150 feet of bulk roll of it in my freezer.
02-26-2014, 12:30 PM   #12
Otis Memorial Pentaxian
Chris
You and me both. T-MAX 100 is great, but Pan-X has a certain look to it.
Hoarder...
02-27-2014, 02:43 PM   #13
ChrisPlatt's Avatar
Besides TMax 100 what are folks using for slow, fine-grained film nowadays?
My one attempt using still-available Ilford Pan F years ago came out real muddy...
Chris
02-27-2014, 02:56 PM   #14
Chris
I shoot 100TMX and 100ACR at EI 12 and get super fine grain.
02-28-2014, 07:40 PM   #15
Chris
Fuji Neopan Acros 100 is nice and has incredible reciprocity characteristics for long exposure. Fuji claims that its spectral response is orthopanchromatic meaning that sensitivity is biased to the blue end of things.
Other options include:
  • Adox CMS 20 II (Ultra fine grain, requires special developer)
  • Adox Silvermax 100 (non-tabular, fine grain, silver rich)
  • Rollei Retro 80s (very fine grain, extended red sensitivity)
  • Rollei ATP (think Technical Pan for today's shooters)
---------- Post added 02-28-14 at 06:51 PM ----------
And there is the key (or at least one of them). Media resolution is not the same as system resolution and even the best 4x5 scanning digital back is only as good as the lens mounted in front of it and many large format lenses are not really that good by 35mm and APS-C standards.
Summary? It is probably best to not be attempting to compare apples and oranges based on the reflective index of their skins.
adox, calc, design, dpi, film, fuji, grain, inch, lenses, logo, pan, photography, pixels, px, resolution, rollei, screen, sensitivity, size
Need film "Best film for the job" kaiserz Film Processing, Scanning, and Darkroom 15 05-03-2012 09:23 AM
Getting started with film... let's talk about the film film! KeithM2 Film SLRs and Compact Film Cameras 18 02-26-2012 09:22 PM
Nature DA 40 Ltd shows resolving power lectrolink Post Your Photos! 3 12-25-2011 12:07 PM
Best 40 for film (film only, please) GeneV Pentax SLR Lens Discussion 24 12-31-2010 07:20 PM
Out-resolving, fact or fiction? rdrum76 Pentax SLR Lens Discussion 20 01-24-2009 10:47 AM
All times are GMT -7. The time now is 04:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
